coil spring spacers - Ford Truck Enthusiasts Forums
coil spring spacers
Old 01-24-2012, 01:36 PM
FordOwnerJoey FordOwnerJoey is offline
FordOwnerJoey is starting off with a positive reputation.
coil spring spacers
Wheres a good place to get coil spring spacers at?
This is the style Im looking into, but not 1.5" maybe like 2 or 3" and for the front springs. Amazon.com: ReadyLift 66-3015 1.5" Rear Coil Spring Spacer: Automotive
If I do this, what else am I going to have to change on the front end since its a TTB 87 f150 (300-six, 4x4, 4 speed)
the rear Im thinking about just doing the shackle flip kit, my friend can get me one from someone he knows who makes them where the new brackets actually bolt right into the stock holes.
Anyone have any problems with these spacers?
Old 01-24-2012, 01:42 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Coil spring spacers are not really the right way to lift a truck. I would get a lift kit instead. Anything more than 2" will require drop brackets anyway, and anything up to 2" will require new shims to correct the camber.
Old 01-24-2012, 11:56 PM
Thumper19's Avatar
Thumper19 Thumper19 is offline
Thumper19 is starting off with a positive reputation.
I was always told to never use no more than .5" spacers under coil springs
Old 01-25-2012, 12:01 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
Well I got my 2" spacers off eBay. Seem I be good quality. But I haven't installed them yet that's my plan for this weekend
And the rear I'm goin with a 3" block to give it a bit more rake.
Old 01-25-2012, 01:04 AM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
i have 2.5 spacers and didnt have to change anything. when i got the alignment they didnt need new shims. and essentually whether you use spacers or buy a lift with spacers your doing the same thing.
Old 01-25-2012, 08:35 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I'd only use leveling springs like what Superlift offers or replacement F250 springs from Moog.
Old 01-25-2012, 08:38 AM
I don't see the point to the 3 inch blocks. Then it'll have even more rake than stock. If you are going to put rear blocks on, go with 1.5.Don't get aluminum blocks. Get name brand cast iron or steel.
Old 01-25-2012, 09:06 AM
The blocks are procomp blocks so they are name brand. I was originally looking for the cast ones but my local off road shop had these in stock and gave me a good deal
When looking at my truck from the side it almost looks level as it is. So I wanted to bring the back end up a bit farther then the front I like the look with the back and a bit higher (not drastically raked)
Old 01-25-2012, 10:49 AM
andym's Avatar
Quote:
Unless either your front springs were sagging 2.5" from their stock height, you used i-beam drop brackets, you have a solid front axle, or your tires look like this: \--/ then what you say here is not possible in the universe we live in.
Old 01-25-2012, 11:40 AM
Like Andy said there us no way the alignment isn't off if the front has been lifted.
I don't care if the rear blocks are name brand. If they are aluminum I wouldn't use them on anything. The same goes for the front ones. What material are they?
Old 01-25-2012, 12:17 PM
Front blocks are delrin
Old 01-25-2012, 12:30 PM
I didn't like the the aluminum block idea either. I just found a set of 2.5" cast ones for 1/3 of the price of the aluminum ones so gunna bring them back and pick up the cast
Old 01-25-2012, 12:36 PM
andym's Avatar
I don't know why anyone would even make aluminum blocks. To save weight? lol
Old 01-25-2012, 01:14 PM
Not sure but they were $125 compared to the $45 for the cast ones. The aluminum just had offset pins not a taper...
Old 01-25-2012, 01:54 PM
deljac's Avatar
when i put mine on it brought my front end up a little higher than level. think what ya want but my alignment is good and i didnt change anything else.
2008 2009 2010 F250 F350 parts, need to clear out garage 09f250v10 1999 to 2016 Super Duty 1 09-21-2016 11:23 AM
ReadyLift on a 2015 Ford F-350 gustrider4 1999 to 2016 Super Duty 9 02-25-2015 02:50 PM
Front Coil Spring Spacers CourierYVR Aerostar 8 07-22-2013 01:08 AM
Bilstein Leveling kit / Titan / Ready Lift rear install : F250 my996duc1 6.7L Power Stroke Diesel 35 06-01-2012 08:45 AM
Any input on this Readylift 05-07 F350 2.5"/1.0" Kit 66 BADBOY 1999 to 2016 Super Duty 3 11-21-2009 08:15 PM
Tags
1989, 4x4, 89, bigger, coil, coils, f150, ford, forum, front, lx, spacer, spacers, spring, thunderbird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
