Is there an easier way to replace the front (side) marker lamp bulbs? I have one burned out, discovered at inspection, oops. Manual calls for entire headlight assembly needing to be removed to replace bulb. 99 Super Duty.
On my 02 there are 2 screws between the marker and bumper. Pull those screws and there is a clip in the top corner that just pops out. H/L stays in, marker comes out. Hope this helps.
