Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 01-24-2012, 09:35 AM
Modified 99 Modified 99 is offline
Garage is empty, add now
Modified 99 is starting off with a positive reputation.
Engine Oil Cooler
Has anyone added an engine oil cooler to their Edge?
I'm thinking about adding one using a sandwich plate between the oil filter and engine.
I recently had an oil analysis that indicated oxidation.
One of the primary contributors to oxidation is heat.
Are there any technical issues with the engine oil pressure or flow that would/could be a problem?
  #2 (permalink)
Old 01-27-2012, 05:15 PM
Thanks for all your help. I'm overwhelmed with the response.
I got the answer from another source.
  #3 (permalink)
Old 01-31-2012, 11:40 PM
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
Basically, the lack of response answered your question.
A) Why have your oil analyzed--are you trying to run it longer than recommended?
B) If you have an oxidation problem that you say is caused by heat, why not just change to synthetic oil?
If there was a heat/oil life problem in the Flex, I would think there would be some mention of it on the forums.
By the way, what was the response from another source?
Joe
__________________
2009 F450 Lariat CC 4x4
2005 Mobile Suites 36TK3
2011 MKX
Tags
37, 400, cooler, davidson, diesel, ecoboost, engine, f150, filter, ford, harley, oil, plate, sandwich, scape
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
