2002 F250 Water Pump :(
Ok, so I had a small coolent leak around the thermostat. So I proceded to take the 3 small bolts out and mind you not they were sorta rusted. I broke the bolt on the front side of it. Do you think its possilble so tap and drill out with the pump still in place, are am I SCREWED? I havnt try the other 2 bolts yet as I didnt want to FUBAR it any more!
The bolts for the thermostat housing thread into the pump, OP was asking if they should try without removing the pump, didn't sound like they were replacing the pump.
Changing the pump is something to consider. Have you replaced it before? How many miles are on it? When is the last time you changed your coolant? Hoses? Might be a good time to get it all done. Something happened to me and that is what I did. Thanks to partsguyed and riffraff for their Great deals.
Not sure a water pump is something I would just change on a whim, but I guess it cant hurt anything. I have had to do mine twice since I have owned and always had ample warning. Drip Drip, drip drip drip, drip drip drip drip, finally a little stream. Dont recommend waiting that long, took a few days till I finally said alright might want to tend to that.
How many miles on the truck? Might just want to order a new pump from Clay at RiffRaff, new thermostat, T-stat housing and the 3 bolts and plan on a weekend project. Good reason to flush out the cooling system and put some new koolaide in the system too!! Preventative Maintenance!
I just received my new supplies from Clay and am going to be doing some PM on mine in a few weeks, with 145k it probably wont be long and I would rather do it in my driveway as opposed to trying to do it on the side of the road or worse having to have it towed and letting somebody else do it for 2 or 3X the cost of doing it myself.
Like has been mentioned, get an "easy out" to use with a reversible drill. It will be difficult given that those bolts are not very large, but it can be done, especially since the pump is not original. If you're dealing with the back bolt position, I would remove the pump to do the work. If it's on the front side, then you probably have room to do the work without removing the pump.
