Anyone changed their lift struts for the rear glass? I have checked Monroe and Strong Arm brands. Both are so stiff that i cannot compress them by hand. I am am afraid the rear glass will break when i try to close the window. Any guidance appreciated.
When I replaced mine I had that same thought. It seemed like it took alot of force to close the glass, but I have not had any problems. I assume over time it will get easier & easier until they don't hold again.
Went ahead and swapped them out with Strong Arm brand struts from Advance Auto. $26 each, less $20 per pair after online discount code.
Took about 5 minutes each side to R &R . Glass is intact!
Thanks for your support!
