1960 Ford F500 tire/wheel questions
I think I've lined up a set of rv 19.5 wheels with 8x19.5 tires on them and before I go ahead and get them I was wondering if anyone could point me towards some pictures of trucks similar to mine with the 19.5 wheels on them? They are a good bit smaller and I'd like to see what they look like compared to the big 'ol 20's. I like how the 20's look, but they're no good if I can't drive on them.
Also, if anyone could tell me how the downsizing in tires affected their overall gearing, that'd be helpful.
Anything else I should know before I get the tires? Here's a pic of one of them, pretty much all the 5 lug rv wheels work, right? Are there ever any concerns with drum brake interference or rubbing between the duals on the rear or anything like that and I can use all the lug nuts/wheel hardware, right?
I'll be replacing some of the tires in the future, 225/70R19.5 seem to be the right replacement for 8x19.5's right?
I will give the opinion that you don't want 225/70R19.5 tires. They will be only 32" tall and look pretty short on one of these trucks. The 8R19.5s will be between 33" and 34" tall and look much better. The only way to get close to your stock 20s with 37-38" diameter is to find some 22.5s. They will be harder to find than the 19.5s. Stu
I have gone ahead and done the 19.5 swap, and it worked out pretty well. I have 245/75R19.5 on the front and 8r19.5 on the rear. It's a little tight around the rear drums but they fit great, just like Stu said they would.
Here are some pictures, you should be able to compare it to the pics on one of my other posts to see the difference of the truck's look overall. It takes away from the quasi-bigrig look that the huge old tires give it, but it definitely isn't to much of a low rider either.
It did change the gearing quite a lot, but it pulls a load really nicely now, much better than before. It did sacrifice some top end speed of course, but you don't own one of these for top speed.
It feels much more stable.
Let me know if you have any Q's anyone.
And a before picture.
It's got a Chevy 327 and a 4spd and the cable drives the Ford cluster, with the smaller tires it puts out some pretty crazy readings. I'll get 55mph on the speedo at around 40mph actual.
He's calculating based on GPS miles vs. fuel used. It's got a one barrel carb and I drive it pretty conservatively, so maybe that helps.
panic
10-10-2016 11:48 AM
