Need Insteument Cluster
1976/79 F100/350, 1976/86 Econoline, 1978/79 Bronco with Oil & Amp Warning Lights
Originally Posted by fmc400
If you pull it from a later model van, the cluster back will be made out of hard plastic and not the composite material that was originally installed that can TURN TO DUST before your very eyes!
D6TZ-10K843-C .. Printed Circuit Board-Use with Oil & Amp Warning Lights / Marked: D6TF-10C956-CA / Obsolete
Applications: 1976/78 F100/350 & Econoline / 1978 Bronco.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
D9TZ-10K843-A .. Printed Circuit Board-Use with Oil & Amp Warning Lights / Marked: D9TF-10C956-AA / Obsolete
Applications: 1979 F100/350 & Bronco / 1979/86 Econoline.
GREEN SALES CO. has 1.
E1PZ-10848-B .. Hard Plastic Cluster Back-Use with Oil & Amp Warning Lights / Obsolete
GREEN SALES CO. has 2.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 108 = 800-476-9653.
Applications: 1981/86 Econoline...and:
This cluster back was also the FoMoCo Service Part Replacement for the POS composition cluster back that was installed in 1976/79 F100/350's, 1976/80 Econolines, 1978/79 Bronco's.
So, it's possible that these vehicles as well will have it. Some were replaced under warranty, some were replaced customer pay, some were replaced by individuals, but some were never replaced.
I used the rear plastic from a van and install the 73-79 gauges and rear printed circuit board. I have at least 3 clusters set up like this. I put them together in junk yards this way then buy the hybrid cluster as once piece. lol. I usually only do it when I come across an all silver gauge bezel as I like that color the best and its the hardest to find (from my experience), I think it was only used in late 79.
...for the POS composition cluster back that was installed in 1976/79 F100/350's, 1976/80 Econolines, 1978/79 Bronco's.
I might replace the cluster in the 78, but only the right side illumination lamps don't work. I can live with that!
PapaBearYuma
Coastal68
08-25-2016 06:18 AM
82fordowner
11-05-2014 12:10 PM
RebelPride67
20
03-11-2005 09:10 AM
