87 ford f150 no injector pulse - Ford Truck Enthusiasts Forums
Old 01-23-2012, 07:39 PM
LeRoy Coverdale Sr. LeRoy Coverdale Sr. is offline
LeRoy Coverdale Sr. is starting off with a positive reputation.
Unhappy 87 ford f150 no injector pulse
I have an 87 4x4 4speed 300 with good spark, and no injector pulse, fuel pumps will not turn on from the computer, it sends no ground signal to trigger the F/P relay, this is a problem that is driving me crazy! I have replaced a computer that had visable water damage and a horrid smell! checked al the grounds and all are good clean and tight! can someone here possibly help me in this major problem! the truck ran before with the F/P diagnostic plug jumped to ground, and it ran good, then a week later the truck just died! fuel pumps running, and no pulse good spark though! Blue-purple spark
Old 01-23-2012, 08:29 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
When you turn the ignition key to On, you should hear
the EEC relay click. That applies 12 volts to the computer.
An indication the computer has power, is the Amber
Check Engine light on the dash should be on. If it is not on
you need to check the power and wires at the EEC relay.
The EEC relay circuit is protected by two fusible links.
One of the links is at the starter relay lug (positive terminal
lead from the battery). The other fusible link protects the
Red wire at the EEC relay.
The Fuel pump relay and EEC relay are located on
a bracket on the driver side plastic wheel well
housing behind a plastic cover.
Are you saying if you ground the Tan/Light Green wire at
the diagnostic plug the fuel pumps do not run?
Here's a schematic for a 88. 87 should be close.
Old 01-23-2012, 08:36 PM
yes the relay clicks when i turn on the switch, but the check engine light has not functioned since i recieved the truck, i did get a code 87 and a code 67 they were the only codes i got retrieved the codes with a test light and a jumper wire
Old 01-23-2012, 08:55 PM
Quote:
Originally Posted by LeRoy Coverdale Sr. View Post
yes the relay clicks when i turn on the switch, but the check engine light has not functioned since i received the truck, i did get a code 87 and a code 67 they were the only codes i got retrieved the codes with a test light and a jumper wire
Code 87 is check for 12 volts at the fuel pump relay. I guess this indicates
the computer doesn't see 12 volts at the fuel pump relay.
Take a good look at the fuel pump and EEC relay sockets. They get
corrosion around the socket pins.
You should measure 12 volts on the Yellow which is always hot.
When the fuel pump relay is energized the 12 volts from
the Yellow wire passes thru the relay contact and provides
12 volts on the Brown wire which goes to the fuel pumps.
On the Red wire there should be 12 volts when the ignition
is On.
Code 67 is the clutch pedal was not depressed during key on engine off test.
Old 01-23-2012, 09:12 PM
i guess that could be the problem, but i still have the issue of no injector pulse either, and the fuel relay works when you connect it to a good ground, at the STI connector, is it possible that the injector pulse is not getting a signal from the dizzy? like not getting a PIP signal?
Old 01-23-2012, 09:22 PM
Well the PIP sensor triggers the TFI module and the TFI provides a signal to
the computer. Do you have a tachometer and if so does it show a valid
rpm when you crank the engine?
Does the engine run if you spray some starter fluid in the throttle body?
The computer should ground the fuel pump relay for about a second
when the ignition is turned on. It should ground the fuel pump
relay as long as the engine is cranking or running.
Old 01-23-2012, 09:36 PM
it tries to run on starting fluid, and yes i have a tach, but it goes high during cranking reads around 500 to 700 rpm and is kinda bouncy,and i do not hear the fuel pump when i turn on the ignition, nor do i hear it during cranking without the test wire and yes the pumps only seem to run when i ground the test plug connector
Old 01-23-2012, 10:24 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like a bad computer.
Old 01-23-2012, 10:27 PM
subford's Avatar
It could also be no small black with a green stripe ground wire at the NEG (-) post of the battery.
Also maybe no power on the two power pins of the computer (1, 37 & 57).
Old 01-23-2012, 10:28 PM
there is no wire like that at the neg post on my truck, i will loof or it tomorrow and reply! thank youfor the insight!!! )
Old 01-23-2012, 10:37 PM
The symptom that the primary coil of the fuel pump relay is not
grounded by the EEC when you first turn the ignition on does point
to the computer.
When the key is turned to on, power is applied to a timer circuit
inside the computer. It turns the fuel pump relay on for one second
to prime the fuel system.
At the negative battery terminal there should be two small ground wires in
addition to the large ground wire that I believe goes to the engine block,
I think one of the smaller ground wires is for the computer. Can you
verify that wire is making a good connection?
Old 01-23-2012, 10:44 PM
to the computer.
there are no other wires at the neg terminal on my truck, I will look for them tomorrow and then we will be in better shape i hope
Old 01-23-2012, 11:05 PM
The other ground wire is for the ABS brake proportioning valve.
This info is for a 88 so I don't know if the 87 is the same.
That smell you mentioned is probably a dead mouse some where
and it probably chewed up the wiring harness.
Any signs of mouse droppings or a nest which looks like a pile
of lint?
Old 01-24-2012, 02:39 AM
deeznuts822's Avatar
deeznuts822 deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
Im betting on the eec relay or the connector being bad. If the eec relay dont energize the fuel pump relay,It don't energize the eec either. So if you don't have fuel pump prime when turning the key on, and no check engine light, I would check the mentioned above If they are fine then possably be needing a eec.
Old 01-24-2012, 07:39 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
If it's never been replaced, the EEC relay should be the brown one.
1990 f-150 4.9L no fuel. relays tested. Power to pump. pump works when hotwired. FordAnne 1987 - 1996 F150 & Larger F-Series Trucks 7 12-30-2016 12:57 PM
Injector problems Firetruckmark Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 01-14-2016 09:41 PM
1986 F150 No Injector Pulse calebo10 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 03-29-2015 05:10 PM
no injector pulse + no fuel pressure ford 300 ford 300 1987 - 1996 F150 & Larger F-Series Trucks 8 09-24-2012 08:51 PM
PCM Bad? 94 Bronk 5.0 MAF E4OD 95F350XL 1987 - 1996 F150 & Larger F-Series Trucks 18 07-06-2010 08:04 PM
Tags
300, 87, 88, 94, computer, diesel, eec, f150, ford, fuel, injecter, injector, location, pulse, relay, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
