Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape & Escape Hybrid
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
  #1 (permalink)
Old 01-23-2012, 06:24 PM
sontours sontours is offline
2003 Ford F-250
sontours is starting off with a positive reputation.
Rough Idle, Lack of power 2001 Tribute V6
I just recently acquired a very nice 2001 Mazda Tribute V6. It has 133k on it. It was not running when I got it. The PO said there were cylinder issues?
I spent some time on it and did get it running. It had a couple melted vacuum lines (near egr pipe). I have spent a couple days changing out a few parts trying to get it running smooth. It did for a short time seem to run right, but when I shut it off and restarted it went back to rough. Sort of a miss.
I have replaced the plugs, intake gaskets upper and lower, several of the boots and one coil. I also replaced the TPS, IAC, pcv valve and EGR vacuum solenoid. Didn't want to throw parts at it, but napa had em and I tried em.
I had scanned it before anything and got no codes. I checked the codes on the odometer and some are unknown and others are low voltage and high voltage...
I will get those codes for anyone who can decipher the others.
I keep thinking I hear a vacuum leak coming from the rear valve cover where the breather tube attaches. What is curious to me is that when I disconnect that hose from the valve cover there is no change. Also where the hose attaches to the intake rubber tube through a tee fitting, when I pull that off there is no vacuum coming from that hole. Not sure if it should but wanted to mention that.
My gut tells me it is running on 5 cylinders and only at higher rpm will the 6th kind of kick in. On a test drive it does not accelerate well at all, but you can rev it up nicely.
I used some WD40 to check other places for leaks, but cannot find any. I am not sure if the sound I am hearing is really a leak or just the sound these engines make when breathing.
The local Mazda dealer is 25 minutes away and I am not positive this would make it like this.
I did clean the MAF and it looks like it had been replaced recently as well.
Exhaust comes out fine i believe, does not seem to be clogged.
Any ideas?
Thanks in advance,
Phil
  #2 (permalink)
Old 01-25-2012, 01:58 PM
2003 Ford F-250
Update so far
So I pulled the intake to check all the gaskets and replaced the PCV hose. I also changed the boots on the coils so they are all new boots and one new coil.
Still runs rough.
I decided I might as well change the oil since it had been over a year since it had been driven. I saw the O2 sensor up front and decided to remove it. When I put my finger in the hole there was a big chunk of something in there. Too big to get out. I tried with a vacuum.
My guess is that the cats are fried so I am looking into that process right now.
Tags
2001, 2003, codes, fi50, ford, high, idle, idles, idling, lack, loss, mazda, power, rough, rpm, tribute, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
