1994 idi turbo diesel downpipe
#61
Yep I just received that education a few minutes ago. Three trucks. Non turbo, turbo idi mine, and94.5 hydrostroke. OK I found out on mechanical systems you adjust fuel pump pressure. I am assuming there is a sweet spot where the peak mpg is at. Any ideas where this is? Or am I totally wrong and leave it alone for peak mpg. Thx
#62
#63
Received 3,106 Likes
on
#65
#66
After reading the writeup I understand how it sheds water. I'll unhook when it snows.
#69
What do I need to install the banks downpipe and straight exhaust. does the downpipe need to be adapted to 3" or larger tailpipe? does it need insulation between the pipe and the firewall? does the downpipe have a bend at the bottom? Is there room to weld on the tailpipe after connecting the downpipe to the turbo and if it needs a band to connect to the turbo does it come with it or do I have to purchase one from International or truck shop?
Pitchfork87
04-11-2008 05:40 PM
TexsDixieDiesel
12-20-2004 09:28 PM
Fourwheelinj1
10-13-2004 07:54 AM
