08 heater sound and control issues
OK, there is a tick tick sound under the dash.
There is a bassy woof woof sound when the heater(only) air is on high.
And, when changing from vents to feet only and other adjustments like that, it dosen't always work. Sometimes the air is coming out of all areas!
The Tick Tick and Woof sounds go away when you turn the temp to blue/cold.
This is a 08 XLT extended cab.
Thanks for any input so I can make my temp changes and keep my mind on mt texts! Sorry couldn't resist
Rob
Rob
The actuator is it just a cable to a door? or electronically controlled?
Well, the sound does go away after you turn it from full hot to full cold - to me that would say that something is working no?
If it is the actuator - has anyone replaced this? is it just getting up under the dash and uninstalling, reinstalling?
thanks guys -
thanks guys -
nlindelldc
01-13-2009 11:19 PM
golfdrinker
11-13-2007 11:03 AM
