Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 01-23-2012, 10:20 AM
rblatch45 rblatch45 is offline
Garage is empty, add now
rblatch45 is starting off with a positive reputation.
97 explorer seatbelt connector repair
Any suggestions on best way to approach replacing the female seatbelt connector on the driver's side of my 97 Explorer?
Any advice is welcome. Thanx in advance.
Cordially,
RBlatch
  #2 (permalink)
Old 01-23-2012, 12:23 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Replace the attachment..... Philip
__________________
97, 4Dr, Controltrac, X engine, 390k
  #3 (permalink)
Old 01-23-2012, 01:34 PM
Yup. That's the part I need to replace.
  #4 (permalink)
Old 01-23-2012, 01:51 PM
shorod's Avatar
shorod shorod is offline
2010 Lincoln MKT
My Garage
shorod has a good reputation on FTE.shorod has a good reputation on FTE.
Are you referring to the seatbelt latch itself or the electrical connector for either the belt minder or the pre-tensioner?
If the latch itself, then the best approach is probably to buy a new one, remove the driver's seat, and using a large Torx bit replace the assembly. The most cost-effective approach is probably to get a used latch from a salvage yard.
The more detail you can provide the forum regarding what you are trying to accomplish, the better the forum will be able to help.
-Rod
  #5 (permalink)
Old 01-23-2012, 02:26 PM
" replacing the female seatbelt connector on the driver's side of my 97 Explorer? "
Thought I did that. Sorry. Yes. The latch. Is there an "easiest way to do it" method of doing this?
  #6 (permalink)
Old 01-23-2012, 02:52 PM
explorerjwd explorerjwd is offline
1994 Ford Explorer
My Garage
explorerjwd is starting off with a positive reputation.
I recently replaced the latch on my 94 explorer. After doing a lot of research I replaced the latch by removing the center console and adjusting both seats as necessary to provide access to the torx bolt attaching the latch to the driver's seat. I have a simple center console which does not attach to the dash. Other types of consoles may complicate the center console remove and install procedure. Instead of buying a used latch, I opted for a new latch from the local Ford Dealer. Might as well spend a bit extra for a new latch from Ford and end up with a proper replacement. The latch comes with a plug that connects into a circuit that is involved with the air bags. Disconnect the battery before you start!!!!
  #7 (permalink)
Old 01-23-2012, 07:34 PM
dan8052's Avatar
dan8052 dan8052 is offline
1996 Ford Explorer
My Garage
dan8052 is starting off with a positive reputation.
I replaced the latch on my '96 about a year ago. Called the dealer, they wanted $81 for a new one and they only had grey (my interior is tan). Went to the salvage yard and found a tan latch for 9 bucks. Wow, what a savings! It just went bad... you get what you pay for.
  #8 (permalink)
Old 01-23-2012, 07:39 PM
shorod's Avatar
2010 Lincoln MKT
My Garage
When I think of a connector, I think of an electrical connector, which are part of the seat belt system and also referred to as "male" and "female". That's the electrical engineer part of me. No harm done, just making sure we're all on the same page.
-Rod
  #9 (permalink)
Old 01-23-2012, 10:06 PM
aquanaut20's Avatar
Quote:
-Rod
I initially had the same quandary..... but solved it by tossing a 2 bit coin.... Kidding... Philip
__________________
Tags
1997, 97, 97explorer, belt, driver, explorer, f250, fix, fixing, ford, latch, repair, replace, replacement, seat, seatbelt, side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
