No difference in mileage.
There was a post on here about getting better mpg by using non alcohol fuel. I am staying in SW florida for the winter and a gas station near me sells pure gas.It is priced about 60cent per gallon more than reg.I have a 2010 F150 4.6 three valve 6 speed 4by4 supercab.As an experiment I ran two tanks of pure gas through it and found very little if any difference in mpg.Just my observations.
Just for kicks I'll try one more tank.I'm down to a 1/4 tank on the second tank.One of my tests is I take a 50 mile interstate drive every week to visit some friends every week.After I'm on the freeway and have the cruise set I reset the avg.mpg. At the end of the 50 miles I,m just over 19 mpg,which is the same as I was with ethenol fuel.Wind and temp are pretty much the same.I have hand calculated both tanks and find no difference.(I have hand calculated every tank since the truck was new) JMO
If you are comparing the fuel mileage in Florida to that of Michigan you might should consider the climate differences as well. Not to mention the altitude in Michigan is 500-1000 ft. above sea-level. Florida is generally less than 500 ft. Fuel additives could vary a little.
I know my trucks get noticeably different fuel economy in the summer than in the cooler and cold weather. During a trip to and from Colorado last September, my truck ran just fine on the 85 octane fuel while I was there but my fuel mileage was noticeably lower.
youngster
12-23-2001 10:22 PM
