C-6 tranny, power hog? - Page 2 - Ford Truck Enthusiasts Forums
Old 01-27-2012, 06:26 PM
70-360fe 70-360fe is offline
70-360fe is starting off with a positive reputation.
Quote:
Originally Posted by cj06 View Post
a manual wont make any difference for your gas mileage as there there is NO EASY ( CHEAP WAY ) to put a overdrive tranny in your truck !
and with ANY manual tranny your driving habits will play a big role in mileage in as in how long you keep it in a gear before shifting !
By cheap way are you talking about mounting a manual behind a 360, buying aan adpater plate and mod. drive shaft. Or just getting all the parts like flywheel and such or both. If I decidded to this it would be long term and depending on my luck get everything cheap form junkyard. Plus it might be fun to have a 5 speed manual in a 70 f-100.
Old 01-28-2012, 01:08 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
have you looked for a 5spd OD for your truck ? if you did want to go through the process then i would look for a NV4500 tranny out of a 94 & up dodge truck & 92 & up chevy truck , stay away from a getrag tranny from earlier dodges as they are not that dependable !
Old 01-28-2012, 07:10 AM
I've been looking for for an nv3500/4500 for my other truck. The 3 speed saginaw is wearing out. Just though when I go to the junk yard I could look for a tranny for my f-1oo. Do you know if the nv 4500 is direct bolt or do I need an adpator plate.
Old 01-28-2012, 10:59 AM
cj06's Avatar
Quote:
no as they were never put in any ford truck ! just chevy and dodge !
stay away from the NV3500 as it is a weak tranny that wont last long , had 2 many problems not holding up !
Old 07-05-2014, 05:24 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
I know this thread is old, but for anyone searching the info..........I swapped from a C6 to a T19, behind a 351W.
The gain was only 1.5 mpg (running empty, 55 mph); but there was a noticeable power gain; also a 3" increase in vacuum, climbing same hills/same speed.
I'm sure there is a bigger mpg gain with the manual trans towing (or loaded). But I didn't have mpg #'s for the C6 when towing, to compare.
C6 tranny todaman64 1968-2013 Full Size Vans 5 06-24-2015 09:32 PM
C6 tranny todaman64 1968-2013 Full Size Vans 6 06-23-2015 10:48 AM
type f and type fa tranny fluid winginit 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-15-2015 03:46 PM
1978 F150 Ranger C6 Transmission problem IsthatMatt 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-03-2015 11:10 AM
C6 Transmission question Keithfriend 1967 - 1972 F-100 & Larger F-Series Trucks 17 07-19-2014 11:17 AM
Tags
360fe, e4od, ford, horsepower, loss, mpg, parasistic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
