seems sluggish
seems sluggish
hi, i'm looking for a little insight. i got a 83 f-250 with a 300, offy c, edelbrock 600, efi manifolds, hi flo cat and 2.5'' exhaust. it also has a np435 and 4.11s. it seems to work well on the flat and in all gears but 4th. on even a small highway incline it seems almost gutless in 4th gear. I find this odd with the 4.11s. Any input would be great! Thanks
235 85R16s are the same as 32" tires. That'd put you at 2850 RPMs at 65mph. I agree, you should have plenty of power at that point. (I was curious about tires in case you were getting out of your RPM range with the 4.11s).
What transmission do you have? Is 4th a 1:1 or an overdrive?
How old is the cat? Is it plugged? (I know you said it was high flow so I imagine new-er).
Are you certain the vacuum advance is working?
Is the carburetor tuned correctly?
Plugged fuel filter?
np 435 sp it should be 1:1, vacuum advance works, dist. is only 4 months old, it does move when ya give it gas, cats like 2 years old, but 1st carb i used was dumping fuel, could that have ruined it? tuning wise the plugs are light brown and only smokes after several days of sitting. maybe valve seals, but no smoke when running normal.
You did a lot of mods to the engine. You need to recurve the distributor to take advantage of the mods.
Here's a good link. It's for a big block but same basic info.
http://www.reincarnation-automotive....ons_index.html
