HELP!1983 F250 4x4 diesel rear brakes
I bought this truck months ago from an old friend had been sitting for years.After getting to start we realize break petal goes right to the floor.
I replaced both rear wheel cylinders and break lines.
I had a friend pump the breaks and went threw the common bleeding procedure got fluid to come out but break still go to the floor with a bit more resistance than before.
I went threw half a large bottle of nappa dot 3
Do i just need to bleed them better ?
Did i miss something or a special valve ?
Can i get a link to a walk threw for this for my exact truck please.
I need to be out of my place and hauling my trailer Tuesday at the latest and im stuck guys please help thanks
Got it licked thanks guys
Thanks for the support turns out it the main line for the master to rear brake hose was leaking about 2/4 of the way back right in between the frame and gas tank.
I didn't catch this earlier as I have been working on it in the poring rain in a mud puddle in the trailer park on the Oregon coast. If that isn't ford i don't know what is.
Also no one anywhere in town even sell the raw brake line or can order it had to go for jc witney for that. Auto Zone did however have a real nice double flare tool for only 30 buck and you can use and bring back in 90 days if you want kinda of loner cool if you ask me.
When i get moved to the truck is going in the shop and the cab and bed are going to the scrapper....look for my Cab off 1983 F250 restore soon
need more help
ok guys i replaced the line from the proportioning valve to the rear break hose and bleed them out but they still hard to press and not much petal and it dosnt seem like the front breaks are engaging
I have heard about the bleeder pin on the proportioning valve is this something i need to mess with
Can you pump up the brake pedal at all? Step on the pedal multiple times and build up pressure and have the pedal be up high? (Engine not running.) Then, with constant pressure, does the pedal slowly sink to the floor?
Or, does it immediately sink to the floor and can't be pumped up?
Everything you describe, this is with the engine not running, correct?
In any event, it sounds to me like either the power brake booster or the master cylinder, or possibly both, have got problems (barring no leaks in the system anywhere).
Read http://www.autoshop101.com/forms/brake05.pdf about halfway through is some diagnostic info on the power booster that should help you.
How to Diagnose Master Cylinder Problems | eHow.com should help a bit with diagnosing the master cylinder.
Google brings up some YouTube videos, too.
Some people replace both together as a unit as the cost from the parts stores is apparently pretty similar in some cases.
by the way thanks for the reply but sorry i was unclear but when the truck is not running all seems normal its when i start it i have no pedal
also i want to add im pretty much beginner i have done some mechanical things over the years but to be honest im right about my skill level here and i have watched a ton of videos and im going to spend the night digging on here agian what got me this far
My email
My email jtworkmailbox@gmail.com
Thanks for all the help guys
Im going out right now to test all above mention things and yes it has a booster for vacume
