Have you taken the fuel bowl apart before for any reason? When you hook up the electric pump, are you getting fuel out of the tank? Are you checking for fuel with the filter lid off or by opening the drain valve while cranking?
We have tried switching on and off, my girlfriend took my truck and had a screwed it up long ago by putting gasoline into it.
Had to replace the fuel lines and the engine since it just plain died on me afterwards. Even after cleaning the lines and flushing the system with diesel.
Tomorrow I plan on cleaning the fuel bowl filter, hopefully that increases the flow a bit.
You had to replace the engine??? The sending units in the tanks have a screen on the bottom of them. The screens are big mess screens so things would have to get real bad before they get clogged.
What did you do, stay up all night and pull those tanks? If so, your fast. I pulled my tanks a couple of weeks ago and the screens were perfectly clean. Unless you got a boat load of crap fuel.
