99 Ranger 2.5L no start.....but now it does??
Had a bad Friday morning. -1 outside and the Ranger didn't feel like starting (it wanted a day off). It turned over fine but there was no hint of starting. Finally ran the battery dead and left it for Saturday (put a charger on the battery though).
I was preparing to push it into the garage but before I did I checked all of the fuses (good) and then started swapping relays (trying to start it between swaps). After swapping the last two relays (after checking later I found they were for the wiper system) the truck finally started. Now I know the wiper relays have nothing to do with the fuel system.........but is it possible I had a fuel line freeze? And it broke loose (it was +12 outside) by stopping and starting the fuel pump?
Anyway it seems to start just fine now. I also dumped about 6 containers of "Heet" in the tank. Due to this "FUN" I purchased a fuel line pressure tester and want to know the following..........
What is normal turn the key and check fuel pressure (engine not running)?
I'm getting 40. After the pump stops the pressure starts to drop right away.
What is normal pressure with the engine running?
I'm getting 65.
Thanks for any help you can offer!
I'm getting 65.
I'm getting 65.
I'm getting 65.
The fuel pressure koeo should be about 60-65.......it should get there with in 2 or 3 cycles of the key..........the pressure should not drop more than about8 psi in 10 minutes.......
next time it does not start spray starter fluid into the TB and see what happens.....
Thanks
I was just killing some time until my son came over to help me push the truck in the garage by checking fuses and swapping relays. In between swapping relays I was trying to start it. I'm fairly certain it was a gas line freeze. With the warmer temp outside and the starting & stopping of the fuel pump may have broke the freeze loose.
I'm getting 65 when it runs but it drops pretty quick when I shut it off. Leaky injector?
Bought a fuel pressure tester and currently keep it with me in the truck. I'll keep the starting fluid idea in mind.
Thanks
Thanks
scooterspal
1983 - 2012 Ranger & B-Series
06-28-2016 03:36 PM
