Intake Manifold Casting Number
Old 01-22-2012, 01:49 PM
ALL AMERICAN BOY's Avatar
ALL AMERICAN BOY
ALL AMERICAN BOY is offline
here it is
COAE 9425-F
is this original manifold?
where's the casting number on the block?
Have A Nice Day!
Ford 292 &
Cruise-O-Matic
from Ford F100
Old 01-22-2012, 02:00 PM
Harrier's Avatar
Harrier
Harrier is online now
Here is some info on part numbers.
Ford part numbers
So: CO = 1960
A = Full size Ford. 50's Fairlane, 60's Galaxie & LTD etc
E = Engine part instead of Chassis part
9425 = Intake Manifold
F= Well, here is your question. This specifies size or type of engine, but the link above doesn't say.
For comparison, which probably throws things off. My 1955 239 Y-block intake is stamped EBV 9425 0
Here is a thread I just found.
https://www.ford-trucks.com/forums/8...d-id-help.html
Old 01-22-2012, 02:39 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
That is a very common 2 barrel manifold.
Block numbers are usually above core plug which is just above the oil filter. Sometimes they are near the distributor.
Old 01-22-2012, 03:42 PM
ALL AMERICAN BOY
joe
thanks!
charlie
went out and looked.
don't see anything around distributor hole.
long block is laying on oil filter side.
how about some exhaust manifold numbers?
C2TE 8430 A passenger side-crossover system.
Have A Nice Day!
Ford 292 &
Cruise-O-Matic
from Ford F100
Old 01-22-2012, 04:14 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Ford changed numbering systems in the 50s, EB series seem to be 292 Y-blocks, EC series 312 Y-blocks, ECZ- started all the 57 312 PNs I dealt with on T-birds. ED series were Lincoln, I had a 430 that was referred to as an "EDJ" engine, all PNs started EDJ, as in EDJ-9424-, or EDJ-9430-, EDJ-9431-. You get the picture.
Old 01-22-2012, 04:35 PM
ALL AMERICAN BOY
le baron
let me guess.
mine's after they quit doing that?
by the way.
when i do get tranny cleaned off
i'll get pic's to you somehow.
Have A Nice Day!
Ford 292 &
Cruise-O-Matic
from Ford F100
Old 01-22-2012, 06:00 PM
Y-Blockhead's Avatar
Y-Blockhead
Y-Blockhead is offline
That's not entirely true. ECZ was not just 312 PNs. For example a ECZ Block could be a 292 or 312. ECZ-G heads were used on 272, 292 and 312 in '57. ECZ-B manifold was used on all four barrel equipped engines in '57. Ford keeping us on our toes.
Best info for your buck when it comes to Y-Blocks is here; http://www.ford-y-block.com/technical.htm
Just my 1¢.
Old 01-22-2012, 08:40 PM
ALL AMERICAN BOY
y blockhead
thanks!
here's the head casting numbers.
C1TE
mummert says the intake size but not exhaust.
what size are the exhaust valves?
sidenote: this engine has regular fuel pump no
vacuum source on top
just describing engine.
Have A Nice Day!
TomCT55
07-22-2019 02:33 PM
skip4274
06-12-2016 09:59 PM
GLADIATOR65
07-25-2007 05:18 PM
jax1-2
06-25-2004 03:23 PM
Quick Reply: Intake Manifold Casting Number
