Transmission Temps??
Old 01-22-2012, 01:11 PM
mclarengts's Avatar
mclarengts
mclarengts is offline
Im about to do some towing in the near future. My question is what should my tranny temps look like? whats normal, and whats high trans temps when towing?
Old 01-22-2012, 01:34 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
diesel-fitter-bum01 is offline
IMO.
180* is normal,anything over 220* will cook a tranny.
I have a magtec tranny pan and a 6.0 cooler and don't see over 180*.
Old 01-22-2012, 02:00 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is online now
It's a Van Gogh
Just to confirm, one of your 3 gauges is an aftermarket for the trans and one of your tunes is for towing, right? What will you tow?
General FYI: Keeping RPMs up helps keep EGTs down since more air is blowing thru the engine. As for trans the stock 7.3 trans cooler is ok if you are rolling along at 65, but slog up a steep hill at 30 and the reduced air flow plus the increased work load can lead to overheating the trans.
Old 01-22-2012, 03:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
You can run at 220F all day long with no problems. You can go to 250F for no more than 1/2 hour at a time. Those are the Ford specs.
Old 01-22-2012, 03:31 PM
mclarengts's Avatar
mclarengts
Yes and yes for the gauges and tuner. I'm about to do some moving, so I'm looking at a 24' trailer, pulling about 4-5k lbs..
Thanks guys for your feed back
Old 01-22-2012, 03:37 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Crewcab Turbo is offline
Is too cool bad also? Now that it's winter my Trans only gets to 110,120 at best.
Old 01-22-2012, 04:22 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Milwaukee1979F150 is offline
Subrscrible to this one.
My transmission temp is 120oF in 30oF outside. I tried block trans cooler it seem it does help little on cold day.
Didn't ford supposed to had bypass line on transmission with theromstat on it? Tran shop replaced that since old one had cut on line.
Old 01-22-2012, 04:54 PM
mclarengts's Avatar
mclarengts
Who makes a really good/heavy duty trans cooler
Old 01-22-2012, 05:04 PM
Crewcab Turbo
The factory cooler from a 6.0 diesel superduty is good from what I read here. I believe there is 2 sizes, not sure mabe 26 and 31 row? Both are verry big.
Old 01-22-2012, 05:50 PM
mclarengts's Avatar
mclarengts
Old 01-22-2012, 08:51 PM
Mark Kovalsky
Yes, it is. Covering the cooler will help.
There is a bypass on the transmission. It does not have a thermostat. It has a pressure relief valve. If the cooler circuit gets restricted it opens to continue to provide lube to the rear of the trans. It does not help warm up the transmission.
Old 01-23-2012, 08:02 AM
mclarengts's Avatar
mclarengts
Good info..
Old 01-23-2012, 09:27 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
Does anyone remember a write-up where someone put a hydraulic fluid thermostat device in the transmission fluid line? The device would block or reduce the flow of fluid to get the tranny fluid to operating temperature and then work (by opening or closing as needed) to hold it at that temperature. I've hunted all over and can't find the thread...can't say for sure I read it here though. Any thoughts on this Mark? Would 180 degrees be the "ideal" temperature target?
Old 01-23-2012, 10:00 AM
Milwaukee1979F150
I remember see 1 thread about TRU cooler with thermostat built inside but I would like find one that you speak about hydraulic fluid thermostat device.
Old 01-23-2012, 10:48 AM
mueckster's Avatar
mueckster
mueckster is offline
This is the Derale Fluid Control Thermostat Derale Cooling Products 13011 - Derale Performance Fluid Control Thermostats - Overview - SummitRacing.com that I currently have installed to bring up my cold weather fluid temps. I am experimenting with getting my temps up a little higher to aid better mpgs. I have mine mounted to bypass the TruCool and use only the stock coolers until the additional cooling is needed.
Quick Reply: Transmission Temps??
