crew cab and 4X4 beds
So I've noticed that just about every crew cab or 4X4 I've ever seen had the old style bed on it, the 58-60 bed that was used until 64(? or was it 63?) anyways, I was wondering if it was possible to when purchased new, not after the fact done, get it with the bed that matches the cab lines? Also, was there such a thing as a crew cab with a long bed? I haven't seen one yet, my brother and I would like to, as soon as we get some money and finish our current trucks, somewhere find, or most likely build a 4X4 crew cab. planned to be a long bed, and most likely make it a ranger.
also, I noticed up top it says
The UNOFFICIAL resource center for Ford Truck enthusiasts
anyone think it should say the BEST?
All Ford Crew Cabs till 65 were made by the after market and made on A standard long bed factory chassis for F350s and F250s 2 and 4 wheel drive. All used the factory bed that came on the donor truck. The bed was cut down and modified to fit.
The first factory units came in 65 with the short bed in the case of four wheel drives being the 57 to 63 and the 2 wheel drives receiving the 64 up bed. A long bed was only available on 2 wheel drive F250s and 350s. Ford made the chassis wheel base to fit the cabs and beds.
The aftermarket continued to make crew cabs after 65 and used again what ever bed was supplied on the long bed truck, cut down to fit. Its why the beds look hokey and home made..
Garbz
Garbz
Long Bed Crew Cab
Now you've seen one!
I have a 63 F100 Crew Cab with an 8' Long "Wrong" Bed (57-60 Fridge side type bed) NOT cut down or modified. It was built by the Stageway Coach Works (a division of the Armbruster Corp which is still in business BTW) in Fort Smith AR. It is my understanding that this particular truck was used in the old patches in Northern Arkansas. Which makes sense when you see the rusty floor from the salt water used in the drilling process.
It has "inside hinges" on the rear doors, and the lines from the front doors follow uninterupted over the rear doors and around the back of the cab as the single cab did. On the "factory" crews I've seen that line is interrupted.
The "matching" bed (that follows the lines of the cab) was not introduced until 1964. It would be "possible" to put a 64 bed on an earlier truck, but it is my understanding that the wheel bases are different on the 64 and later trucks and would require bed and/or frame modifications.
Like many, I'm not a big fan of the "wrong bed", but I'll have to say that they are growing on me, especially in a dark color (blue/black). My plan is to substitute a long bed flare side bed for the current bed. In fact I bought my F250 (just purchased) with the idea of putting the long bed on the crew, but that idea was immediately vetoed when my wife and 13 year old daughter saw the F250. "Don't touch that truck! It would be a sin." So, I'll be on the hunt again for a bed. BTW: It was always my understanding that the crews and 4X4's were all F250's or 350's, but this one belies that theory.
It is a long sucker...totally fills up my 20' deep garage (Note: the pic is before I culled it from the herd in a Northern Arkansas pasture. Doesn't look much different today, but I'm working it).
Grits.
Your Chassis is modified from a factory frame, it was stretched. Most aftermarket suppliers did not do this option as it voids the factory ford warranty. Ford would warranty the truck after modifications to the body but retained stock drive train and underpinnings as the most makers were under licence to ford.
Yours is an exception to that, And in fact resembles a factory 65 crew cab with the space between the doors and the inside hinges.
What is the wheel base on your warranty plate? Photos only please.
Garbz
Garbz
ALL 4WD Styleside pickups from 1961 thru 1966 used the 1957/60 Styleside pickup bed, with one exception.
1966 F100 4WD's used the same Styleside bed the 1964/66 F100/250 2WD's used.
btw: There were no factory F350 4WD's available until 1979.
If...you see one made before 1979, it's an aftermarket conversion.
Your truck is not a factory piece. It was modified by the aftermarket. Your Grandfather possibly paid a body shop to modify a standard long bed Integral cab.
Looks like a good job. Post some pictures of the profile and of the inside steps of the rear doors, hinged and B post. From those i can tell if they are Crown Pieces.
Also post as suggested a photo of the data plate located on the drivers door.
Where are you located in Arizona?
Garbz.
Garbz.
