Need to make a wiring mod to F350 tail-lights - Ford Truck Enthusiasts Forums
Old 01-22-2012, 07:11 AM
Linne's Avatar
Linne Linne is offline
Linne has a good reputation on FTE.Linne has a good reputation on FTE.Linne has a good reputation on FTE.
I am trying to find out if it is possible to disconnect the turn signal function from the brake light, my problem is that here in Finland turn signals must be orange and under no circumstances flash red, so I have made a separate back up light and I have put orange bulbs in original back up sockets now I need to make original brake light to work as parking/driving light and brake light, ther is now a third funktion it also flashes when I put turn signal on.
I have noticed that there is one green wire with a red stripe that brings + to the bulb on both braking and turning, is it possible to somwhere disconnect that turn light function?
Old 01-22-2012, 07:56 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
It's all done in the steering column. I do not know what year truck you have, but on the later ones Ford calls the turnsignal switch the "multi-function switch" because it also has the high/low beam and the hazard flashers(maybe the wipers also).
Most all American cars and trucks are setup the way you are describing, and the turnsignals and the brake light wiring get mixed together and co-ordinated in the turnsignal switch. It will be easier for you to take the original wire in the rear that did the turn and brake(one different wire for each side), and move it down to your new orange bulb. You will then have to go up and find the wire that goes from the brake pedal switch to the turnsignal switch, cut it so it no longer feeds the turnsignal switch(this is usually a lightgreen wire most years) and then splice it to a new wire that you add in, run this new single wire all the way to the rear along the frame rail, and then tie it into the original red light sockets. Tie it into the driver's side and then splice and run it over to the pass side also. This will be your new red brake wire.
The original red bulb should also still have a brown wire going to it, this is the marker/running light wire and you still need this. The brown wire feeds both taillights in the rear and the license plate lights.
Old 01-22-2012, 08:15 AM
Linne's Avatar
Thanks a lot Dave! This sounds like an easy task.
Truck sat for a while and now I have no dash or running lights Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 9 04-19-2015 12:26 PM
74 f100 Dash Wiring 1974 f100 1973 - 1979 F-100 & Larger F-Series Trucks 16 02-24-2014 01:00 PM
03 Ambulance chassis - tailight wiring problems miauctioneer 1968-2013 Full Size Vans 6 01-31-2012 08:22 PM
NEED HELP WITH UNDER DASH WIRING 66 F100 EricAlex66 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-10-2011 03:59 PM
1979 F100 column wiring questions SparkyRnD 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-06-2011 01:16 AM
Tags
2003, 2011, 3rd, brake, f350, ford, light, lights, make, powered, signal, tail, turn, vbulletin, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
