'56 F100 Temp gauge retrofit - Ford Truck Enthusiasts Forums
Old 01-22-2012, 05:50 AM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Ok boys and girls, this has been a burr in my side for a little while now but I think I've got this licked. Most '56 owners know that Ford, in their infinate wisdom upon the switch to 12v, left the gauges as 12v units aswell. Some of you, like me, desire the want to run 'as original' gauges in their rig but cannot get (or afford) the 12v '56 only' sending unit or get it to work in a more modern engine. Well folks, I'm here to tell you I believe i have a low-cost solution to this problem.
Thanks to my father and his ability to re-invent the wheel and do it cheaply, he shared with me this little swap of his. Problem was, he could not remember what year of rig he was stealing parts from. (He'd last done this back in the 70s and described the donor truck as 'somewhat late model' at that time and said they were plentiful in the junkyards aswell. With some picture research and note comparing I think i keyed in on his donors.
Ok here we go-
I sourced a used '57-'60 pickup temp gauge (which came with a fuel gauge and voltage reducer too) from a buddy of mine for free. These gauges differ as Ford stepped back to 6v in '57 and changed the functionality of the temperature sender. This temp sender (as it appears in pictures and by description) is smaller and shorter by far than the '56's sending unit. Because of the large size (mainly length) the '56 sending unit will not work in more modern engines, is usually too long and will bottom out in most intake manifolds before even getting to the threads. The '57-'60 sending unit appears to be MUCH smaller thus making it able to be installed into most intake manifolds of more modern engines. I need to confirm this for sure (haven't actually bought one yet) but from what I've seen in pictures and descriptions, it's a winner. And to top it off, this sending unit is very easy to source and MUCH cheaper than a '56 unit. Of course you WILL need to run a voltage reducer on just this gauge as it is solely designed for 6v operation. No problem, as the stock reducer is available, as well as aftermarket versions too.
Ok here is the rundown on making the '57-'60 gauge work for the '56 dash.
Here is the two gauges. The '56 gauge on the left, a broken unit from a spare dash and the donor '57-'60 gauge. I know it's cruddy looking and the needle will need re-painting but I'll do that later on. Luckily the '57-'60 gauge tested good, so that was a huge score!
Again, back sides of each gauge. The important thing here is that the main gauge housings are EXACTLY the same. The faces and rear mounting flanges are all that is different, and are easily removable.
Here i have disassembled the '56 gauge. You'll need to be gentle removing the face of either gauge as not to disturb the needle. Save the '56 gauge face and the rear mounting plate. The face will pop off easily as it as 3 pinched areas on the edge. The rear mounting plate is retained by the two nuts on the back.
i disassembled the '57-'60 gauge in the same fashion. Using the main gauge body of the '57-'60 gauge i reinstalled the face and the rear mounting plate of the '56 gauge. I didn't repaint the needle just to show you that it is infact the '57-'60 gauge i put the '56 pieces on.
As you can see here, it appears in all fashion just as if it were a '56 gauge. The rear mounting plate and face fit like they were meant to be there.
Here is the newly re-fitted gauge installed into one of my spare dashes. Fits just like it should.
Here i included the factory '57-'60 voltage reducer just so that you'd see what it looks like.
Here's the backside of the '56 gauge with the mounting plate removed. You'll see a couple open holes on the backside with little teeth visable. This is actually an adjustment point for each end of the scale. You'll notice in earlier pictures that the needle wasn't quite to the 'C' like it should be. I corrected this through use of the upper adjustment point.
This better illustrates what you're adjusting. You can see the teeth up tward the top pf the gauge within the housing on one side and the teeth and hole are somewhat visable on the lower right side of the gauge. Two adjustment points, one for each end of the scale.
Here is a picture of the matched sending unit to the '57-'60 gauge.
Part number: B7A-10884-A
Dimensions: 1/4 X 18 X 15/16 Long
Fits: 1957-1962 CARS AND TRUCKS
Seen available on eBay for $15 +shipping.
And there you have it! in order to make the gauge function properly you must have the voltage reducer to bring it down to 6v and also have the matching temp sending unit, in this case a sender for '57-'60 trucks.
One could possibly use a guage/sender combo out of another car or truck even later than '60 provided that the main gauge housing is the exact same dimensions (depth and diameter) and needle sweep. If the main housing matches you'd just swap the rear mounting plate and face. I looked at alot of different gauges on eBay and noted alot of similiarities of these gauges in both cars and trucks thru at least '66 in trucks and I believe '60 or '61 in the cars.
It's also my belief that this can also be used for older pre-'55 vehicles aswell, if one was to switch to 12v and/or the original senders to the 6v gauge are unavailable or too pricey. Again- as long as the main gauge housings are the same, they can be swapped.
Anyways, there you have it. I'll be buying a temp sender here soon for the '57-'60 gauge to positively confirm its much smaller size but if anyone here wants to chime in to verify, be my guest.
Old 01-22-2012, 09:01 AM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Nice tech post Dano!
Old 02-09-2013, 08:29 PM
Roverman Roverman is offline
Roverman is starting off with a positive reputation.
hi guys I need some help Dont know if temp gauge works the needle is always reading hot. I did the folowing checked power is ok when i grounded the nedle goes all the way to cold when i remove the ground itgoes back to hot I tried to adjusted i put it in cold position but when i put power and ground nedle goes to the wron side like is reading lees than cold please help
Old 03-28-2013, 05:57 PM
dadgonebroke dadgonebroke is offline
dadgonebroke is starting off with a positive reputation.
retro gauge and sender problems
Is it just me having this problem with the retro temp senders with matching gauge for the 56 F 100's? My gauge quit working so I ordered the sender/gauge setup from LMC. I was having my mechanic put on a new master cylinder so I asked him to put the sender and gauge in.
He reported back after the install the the gauge didn't move after a test drive. I saw that the package was marked Mac's Ford so I called them and was told it might be faulty. I returned the initial ones to LMC and ordered another from Mac's. Same result with Mac's sender/gauge which had come from Mid 50's Ford parts (marked on the bag).
My mechanic now suggested that I take the truck to a shop in town that specialized in auto electrics. They came up with same result and tested the gauge and sender and the sender wouldn't activate the gauge until 205 degrees. I returned the pair to Mac's and now called Mid 50's and explained to them and then had the new elec. guy talk to them and explain what he'd done to test the sender/gauge.
Mid 50's agreed there was a problem and sent me a new setup gratis with the end result being the same-bad sender that opens at 205 degrees.
Not to let this get the best of me- I've gotten an oem 56 gauge and bought an oem sender from Mid 50's to see if that'll work. Hopefully. I'll have an answer tomorrow!
Old 03-28-2013, 06:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It sounds like you have a temperature SWITCH, for an idiot light, not a gauge sender.
Old 03-28-2013, 07:53 PM
idiot light
Quote:
Good deduction! But after 4 tries- this is getting old. I don't understand- these companies make this sender and gauge specifically for the 56 Ford truck.
Sharing my 56 F100 project.... Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 183 09-11-2015 09:25 AM
Need help with F100 Front Hub identification Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-05-2015 09:55 PM
FE crossmember install modification Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-19-2013 07:20 PM
Comments on Mid-Fifty Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 54 03-06-2012 10:15 PM
Throttle Pedal assy question.. Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-25-2011 06:28 AM
Tags
19571960, 1960, 55, 56, f100, ford, gauge, gauges, light, number, part, plate, switch, temperature, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
