Search: Ford F1 1952 4-speed Transmission - Ford Truck Enthusiasts Forums
Old 01-22-2012, 05:38 AM
rosthaufen rosthaufen is offline
rosthaufen is starting off with a positive reputation.
Hello togehter,
i search some tuneup parts as:
Syncr, drive gear, rears etc.
BR Greg
Old 01-22-2012, 08:04 AM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
I have a whole trans that I dont need if your interested.
Old 01-22-2012, 09:16 AM
Ford Transmission
That's fine..I really needed only parts, but if you have a very good transmission..
Please send me some pictures and what will it cost
to old_mcgreg@web.de
many thanks
Greg
Old 01-22-2012, 11:09 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
It would be helpful if we knew exactly which model of transmission you have, and which gears you need. There should be numbers cast on the side of the transmission case. And if you can post pictures of your damaged parts, we may be able to match them.
Old 01-22-2012, 03:00 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
From the research I have done previously I am guessing only he's talking about one of two transmissions, the rock crusher (markings T8D-1A or 4TA/4Tb) or the synchro silent 4 speed (markings 4TH or T98).
No synchro on the rock crusher... and if you are willing to wait till I finish my T5 swap I have a whole rock crusher verified working (I'm driving on it right now) I'd let go for a song and a dance :p
Old 01-22-2012, 03:40 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Like the guys have indicated, it's not very likely your F1 has a synchro trans.
When you find out which you have, contact Joblot Automotive in NY for the specific parts you need. I'm sure they've shipped to Germany before.
Old 01-29-2012, 01:04 PM
brain75's Avatar
Are you building a museum piece or a practical drivable vehicle?
I saw you visitor message, and just have to double check before discussing the T8 seriously. No synchros, no overdrive, and low is geared for lower than towing - clear down at rock crawling. The stock T8 is undesired, nobody keeps them they all end up in salvage. They weigh 175 pounds (85 kilos), shipping to Germany would be a mint. If you are going to all the effort to put this back together as a usable vehicle I would look for a T-5 and the pieces and parts to convert it over. The T-5 weighs 75 pounds (34 kilos) and is sold internationally (the S-10 donor truck is sold in Brazil and USA but not Euro that I know of).
Old 02-21-2012, 05:08 AM
Ford F1 1952 Transmission (no Steering wheel shift)
Thank you for your help. What transmission would you recommend me
Old 02-21-2012, 03:51 PM
brain75's Avatar
My focus has been on US available transmissions. I did some digging to see if the Chevy S10 pickup version T5 is available outside the US, but so far it doesn't look promising.
Time for some of the European friends to step up and chime in - what did you guys find for options?
Old 02-21-2012, 09:27 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is online now
fifty-two_f1 is starting off with a positive reputation.
If its an f1 then it has the T59 or spur type. A T98 will not bolt into an f1 chassis.
Old 02-22-2012, 05:49 AM
Transmission
Hello together,
yes, it is a 1951 F1 with stock 4-speed (not synchro) transmission!
The T98 is a 4-speed synchro transmission, is that right.
OK i need this..
Who can help???
The shipping goes on CA not Germany!!
Old 02-22-2012, 03:29 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is online now
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
As fifty-two_f1 said, a T98 is NOT going to fit in your F1 without swapping the transmission crossmember, master cylinder, and pedal assembly to one out of an F2 - F6 truck. The crossmembers are riveted in place and changing them is no small task - and that's after you've found a T98 to put in. They aren't so easy to find. In my opinion, there are better choices. I'd either go with a T5 swap or a stock light duty 3-speed.
Old 02-22-2012, 05:31 PM
Only the real men put t98s in their trucks..... those weirder individuals go with zf5s and Fuel injection.... bleck!!!!
Old 02-22-2012, 07:33 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
T98s from later trucks are fairly easy to find. Starting with the 1953 trucks all the four speeds were T98s. This stayed true through the 60s. I am not sure what differences in the T98s there are between years.
Old 02-22-2012, 08:55 PM
The 48-52 T98s have the bellhousing that will bolt up to the flathead 6s and 8s and the 215 ohv. The 53-56 T98s have a different mount in the front and have no rear mount, they hang from the bellhousing..
How to Search Classifieds? Studawg Trading Feedback 1 02-25-2016 08:47 AM
Gun locker Ryan Fazzino WTB - Parts & other 8 10-16-2015 12:39 PM
Testing a search url HIO Silver Testing..... 0 08-17-2014 01:47 PM
SEARCH BAR Edogsf350 6.0L Power Stroke Diesel 8 06-24-2014 06:02 AM
Enhanced Search Functions For Club FTE Members FTE Ken Site Announcements 4 06-12-2003 12:02 AM
Tags
1952, 38, coupe, enthusiasts, f1, f4, ford, overdrive, speed, syncro, t5, t8d1a, trans, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
