ReadyLIFT SuperDuty Anti Wobble Trac Bar Install
Hi all,
Take a look at this install video from ReadyLIFT. What do you think??? Does it seem like the solution to the SuperDuty "death wobble"???
<iframe width="560" height="315" src="http://www.youtube.com/embed/CZsw33SJ-lY" frameborder="0" allowfullscreen></iframe>
IMHO...it looks like a really cool solution...just no experience with it. The install seems straight forward too. Humm...
biz
biz
No. It is only for the 2005 and UP SuperDuty. I personally...do not have an issue with my SD.
I started the thread...in the hopes that someone out there experiencing Wobble or "death" wobble...run into this thread as an informational piece.
biz
biz
Actually...prior to creating this thread...I hadn't seen the cost of the ReadyLIFT unit. OMG...that is a ton of cash...for sure!
One current difference from what I can see...is that the W.C. Motorsports version is for lifted trucks only. The ReadyLIFT...has two different part #'s...to work with stock height SD's.
biz
"Death Wobble" is a result of Ford's coil-spring front suspension (and radius arms) found in the 2005 to present Super Duties. I believe that Ford has addressed this issue in the newer Super Duties.
64031 - '05 - '11 Ford Super Duty Adjustable Pan Rod Bar with Bearing - ICON Vehicle Dynamics
This Adjustable Pan Rod Bar for the 2005 - Current Model Super Duties will realign your front end track alignment within factory specifications. It can be used on lifts from 2.5" up to 9". This bar can easily be installed using factory hardware and can be adjusted right on the truck without having to take it off. This Bar comes complete with our new spherical bearing rod end and rod end spcaers to eliminate the terrible death wobble these trucks have.
the front axle wobbles because some computer retard decided that a ball joint was good at holding the axle still. I thought a ball joint moves abck and forth? o thats right it does good going frod. Basically when you hit something in the road it causes the axle to move side to side because the ball joints moves side to side.
