Audiophile Not Working
Old 01-22-2012, 01:52 AM
Vezhen's Avatar
Vezhen
Vezhen is offline
I have a 2005 Expedition Eddie Bauer in dash audiophile 6 cd/ fm/am radio. About a month ago my cd player started reading disc error, I removed and checked the fuses, after I put them back in the cd player read no cd and the radio worked fine at the time.
Today I had to replace the original battery and now my radio has no sound, it will come and the clock I can see the volume bars when I turn up the volume, but no sound. I did notice that the radio clock and light went dark and came back on twice. any suggestions?
Thanks
Old 01-22-2012, 07:49 AM
Tugly's Avatar
Tugly
Tugly is offline
If an aftermarket unit will fit in the dash, you might consider getting a unit with SD card capability and dump the disks. No moving parts, far more storage capacity, no lasers, and you can step up the capabilities of the unit to include a backup cam. It's just a thought.
It sounds like your unit may be done, but you might have a loose ground or the connector in back of the unit needs to be unplugged and re-inserted (if you're lucky).
Old 01-22-2012, 08:26 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
This thread may help you out (if it's the same head unit):
https://www.ford-trucks.com/forums/1...air-fixed.html
Old 01-22-2012, 02:21 PM
Vezhen's Avatar
Vezhen
Vezhen is offline
Update
Thanks
Thanks for your replys. I found out when I installed my new battery the computer for the radio had to be reset. What I did was disconnect the negative battery cable for 10 minutes and reconnected it and the computer reset and the radio is working fine except for the problem I had for the cd player before the battery change.
01FordEx
02-13-2017 08:35 AM
celltech
27
08-26-2013 07:21 PM
ToMang07
Ford Truck Parts for Sale
12-14-2012 04:59 PM
ppo2
03-31-2009 09:55 PM
f350peter
1999 to 2016 Super Duty
13
06-26-2007 12:14 PM
Quick Reply: Audiophile Not Working
