Audiophile Not Working - Ford Truck Enthusiasts Forums
Old 01-22-2012, 02:52 AM
Vezhen Vezhen is offline
Vezhen is starting off with a positive reputation.
I have a 2005 Expedition Eddie Bauer in dash audiophile 6 cd/ fm/am radio. About a month ago my cd player started reading disc error, I removed and checked the fuses, after I put them back in the cd player read no cd and the radio worked fine at the time.
Today I had to replace the original battery and now my radio has no sound, it will come and the clock I can see the volume bars when I turn up the volume, but no sound. I did notice that the radio clock and light went dark and came back on twice. any suggestions?
Thanks
Old 01-22-2012, 08:49 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
If an aftermarket unit will fit in the dash, you might consider getting a unit with SD card capability and dump the disks. No moving parts, far more storage capacity, no lasers, and you can step up the capabilities of the unit to include a backup cam. It's just a thought.
It sounds like your unit may be done, but you might have a loose ground or the connector in back of the unit needs to be unplugged and re-inserted (if you're lucky).
Old 01-22-2012, 09:26 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
This thread may help you out (if it's the same head unit):
http://www.ford-trucks.com/forums/11...air-fixed.html
Old 01-22-2012, 03:21 PM
Update
Thanks
Thanks for your replys. I found out when I installed my new battery the computer for the radio had to be reset. What I did was disconnect the negative battery cable for 10 minutes and reconnected it and the computer reset and the radio is working fine except for the problem I had for the cd player before the battery change.
2001 F-150 Radio Volume Issues... PalaniRides Electrical Systems/Wiring 7 03-07-2016 11:12 AM
Installed new factory radio now steering controls wont work? dhoff024 1999 to 2016 Super Duty 2 07-31-2015 01:03 AM
6 disc cd changer problems dtingle89 2004 - 2008 F150 0 01-09-2010 04:51 PM
radio wont work 97 explorer mrladylover1469 Explorer, Sport Trac, Mountaineer & Aviator 0 07-30-2004 04:57 PM
Radio Display frozen Thumper4995 1999 to 2016 Super Duty 13 02-11-2003 07:30 PM
Tags
64, 97, article, audiophile, dashboard, diesel, dos, f150, fm, ford, lights, power, powered, radio, sound, taurus, transit, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
