French Ford Flatheads -- new castings, SAE threads - Ford Truck Enthusiasts Forums
Old 04-20-2003, 08:36 PM
mlf72f250 mlf72f250 is offline
mlf72f250 is starting off with a positive reputation.
I was researching flathead fords for a future project and ran across this:
http://www.halibrand.com/flathead_info.htm#GENERAL
They have newer Ford flathead castings, from French military surplus. Not cheap, but most dimensions and SAE thread sizes are preserved (no metric).
It just blew me away that they had used these up until the early 1990s, but I suppose in some applications, the flathead is more compact...
--Matt
Old 11-02-2004, 11:03 PM
devja devja is offline
devja is starting off with a positive reputation.
..I read that somewhere too. If I remember, the France got the rights to the flatty and made it up till the late 80's. I think they were cast steel though and not cast iron. So I've read.
Old 11-11-2004, 08:53 PM
LedheadELH LedheadELH is offline
LedheadELH is starting off with a positive reputation.
Flathead ???s
I was looking around in this junkyard that is seldom ever visited by anyone other than me and a couple others, and I found 2 Flathead V-8's. On had the distributer in the front, and the other had the distributer on the top. what is the difference between these 2 motors, and which one would be better for a build-up?
Old 11-13-2004, 09:35 PM
ptmilan ptmilan is offline
ptmilan is starting off with a positive reputation.
The distributer on the front was used from 1932-1948. The distributer on top was used on the 1949-1953 models. I don't know what it takes to interchange the 2 types. The early ones had an enclosed driveshaft. While the later models (49-53) had an open driveshaft.
Old 11-25-2004, 10:50 AM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
the inclosed drive shaft was called a torqe tube by most
Flathead V8 Rebuild Video ChristiansenP 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-15-2016 06:03 PM
A French Soldier's View of American GI's CarlT100 VetNet 0 06-19-2015 06:38 PM
question about matching number engine 1954 f100 maxtegracing 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 08-03-2013 08:45 PM
1947 Ford COE C69A Flathead Bellhousing adapter?? trfisher5 1947 and Older Ford Trucks 0 09-30-2011 10:47 PM
Just picked up my first flathead (pics) jmadsen Flathead V8 & Flathead 6 3 04-16-2008 01:17 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
dimensions, engine, engines, flathead, flatheads, ford, french, surplus, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
