Anybody know safe operating RPM for power steering pump? - Ford Truck Enthusiasts Forums
Old 01-21-2012, 07:27 PM
Matthew in SD Matthew in SD is offline
Matthew in SD is starting off with a positive reputation.
Will increasing the size of the pulley on the crank make my power steering pump spin too fast?
Right now I have a 6" crank pulley turning a 4.5" pump pulley. If I increase the crank pulley to 7 3/4", am I asking for trouble?
Old 01-21-2012, 09:51 PM
tmcalavy tmcalavy is offline
tmcalavy is gaining momentum as a positive member of FTE.
Which steering box do you have...Bendix or Saginaw? The Bendix box is inherently weak and prone to fail and it is driven by a low-pressure pump. Don't know about the Saginaw PS system. My guess is it might stress the pump and pump bearing unless it is in good shape, and maybe stress a Bendix gear box...more pressure might mean more leaks. The bottoms in the Bendix gear boxes have weak seals. Why are you going to a larger crank pulley?
Old 01-21-2012, 10:12 PM
I have a saginaw steering gear in the truck (which is a 72 F250, 390). Both the steering gear and pump are new (remans).
I put a 3G alt on the truck and am changing over to dual vbelt for the alt. Went to the junk yard today and found the alt, water pump, and crank pulleys I needed; but the power steering pulley is larger than the one I had on there.
Looks like I'm gonna have to locate a 6" pulley and put it on the pump.
Old 01-21-2012, 10:49 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
You would have to spin pretty fast to kill the pump. I had a 351C back in the day that would hit 7500rpm on all stock pulleys. No problems for quite a few years with it.
Old 01-22-2012, 06:43 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Matt, I have a suggestion that might help with no out of pocket cost. Lift the front wheels off the ground, then turn the steering wheel bump to bump about 20 times. This can help purge any air that might be trapped in the system, then give it a test drive to see if there is any improvements. This may not solve your problem but is very low cost.
John
Old 01-22-2012, 07:57 AM
If you can't find a larger pulley I wouldn't worry about it based on what nevrenuf says...slap it together and run it, and keep lookin for a bigger PS pulley or pump with bigger pulley. The Saginaw boxes are strong customers.
Old 01-22-2012, 06:21 PM
I ended up spacing the pump out from the motor and lined it up with the 4th pulley off the crank which was the same size as the old pulley...so far, so good!
John, thanks for the advice
390 belt route? dthut 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-18-2017 01:00 PM
Belts for 300 I-6? What year do I have? 86stepsideF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-27-2016 10:39 PM
Wtb- 78-79 ps pump bracket for 302 FordF100man WTB - Parts & other 4 08-28-2015 08:41 PM
power steering pulley installation tommyblack 2004 - 2008 F150 2 01-08-2015 12:02 PM
460 swap pulley problems mikefender Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 12-10-2010 07:44 PM
Tags
power, pulley, pump, rpm, spin, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
