FX4 Rancho Shocks, Who has checked -were they good or bad - Ford Truck Enthusiasts Forums
Old 01-21-2012, 07:24 PM
PumpDoctor's Avatar
PumpDoctor PumpDoctor is offline
PumpDoctor has a very good reputation on FTE.PumpDoctor has a very good reputation on FTE.PumpDoctor has a very good reputation on FTE.
I think it would be interesting to see how many members have checked to see if their Factory Rancho Shocks that come with the FX4 package where still good or bad. On my truck 3 of the 4 were junk after 7500 miles and never exteneded. I replaced them with the Bilstein 5100 shocks (Thanks to Big Sarge`s video) I noticed my truck starting to pogo over bumps and when towing my trailer. I decieded to go with the Bilsteins over the Rancho 9000 adjustable shocks for one main reason and that is I plan on installing air bags and didn`t see a need for to ways to adjust my suspension.
Thanks to all the FTE members for the issues they bring forward and for the ways they correct them. If I had never become a member on this forum I would have never known what to look for.
Old 01-21-2012, 07:30 PM
GCLL GCLL is offline
GCLL is gaining momentum as a positive member of FTE.
All 4 of mine took over 5 minutes to open if at all at 14000 miles
Old 01-21-2012, 07:32 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
Quote:
I know some of mine are bad, I'll have to go back through them and see which ones, or if any are even good.
Just a quick "double check" here as I don't have experience with airbags, but my understanding of them is that they are for load leveling. As in they are used on the rear axle to help support the weight of the load in the bed/attached (trailer). I would not think they would do much for the "compression" and "rebound" IE - ride quality. The shock absorbers are what restrict the moving of the axles under the truck, air bags don't unless I am not understanding them entirely?
Old 01-21-2012, 07:45 PM
Gunny77's Avatar
Gunny77 Gunny77 is offline
Gunny77 is starting off with a positive reputation.
My factory Rancho's had no rebound after 6k. I now have Bilstein 5100's
Old 01-21-2012, 07:49 PM
juneau92's Avatar
juneau92 juneau92 is offline
juneau92 is starting off with a positive reputation.
Are these Factory Rancho Shocks that come with the FX4 package under the "bumper to bumper" warranty?
Old 01-21-2012, 07:54 PM
_red rocket_'s Avatar
_red rocket_ _red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
I think it would be interesting to see how many members have checked to see if their Factory Rancho Shocks that come with the FX4 package where still good or bad. On my truck 3 of the 4 were junk after 7500 miles and never extended.
They are junk --> Ford Truck Enthusiasts Forums - View Single Post - Bilstein 5100 Shock install with VIDEO!!!
Quote:
Yes, but I was not replacing junk with brand new junk.
Old 01-21-2012, 07:58 PM
PumpDoctor's Avatar
You are correct and I probably should not have worded it as such. The bilstein shocks will work fine for me driving under daily conditions without a trailer. No need to adjust (Personal Preferance). The air bags will help support the load when towing and I can adjust the air pressure down in the air bags to help on compression not so much rebound (which for the most part isn't a concern when towing) for lets say if I have weight in the bed. I'm sure the 9000 series shocks can do this also but again its just a personal preferance.
Old 01-21-2012, 08:23 PM
Rickx Rickx is offline
Rickx is gaining momentum as a positive member of FTE.
I went through three sets under warranty. Finally installed Bilstien 5100s at my expense.
Old 01-21-2012, 09:20 PM
magnumacF250 magnumacF250 is offline
magnumacF250 is starting off with a positive reputation.
anybody know what the rancho model of these shocks are? I've had rancho 5000's on several pickups with good results. I hope the shocks on my ordered fx4 are the lone set of good ones!!
Old 01-21-2012, 10:26 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
3 of 4 of mine are bad. 5,000 miles. Replacements in the mail now.
Old 01-21-2012, 10:50 PM
jmcquarry's Avatar
jmcquarry jmcquarry is offline
jmcquarry is starting off with a positive reputation.
At 3000 miles I replaced the FX4 Raunchos with Bilstein 5100's,,, the factory shocks were trash. Any future trucks will immediately have replacement shocks and replacement speakers,,,love the truck but these items are pitiful, replacing them was not a big deal. Would have gone with Rancho's but very disappointed in the crap they supply Ford, wether it was Ford's specs or not, bad business decision, gives them a bad name.
Old 01-21-2012, 11:01 PM
Dim Sum's Avatar
Dim Sum Dim Sum is offline
Dim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant future
Ordered 9000s today. I can't wait to get them on the truck. I've never driven a Superduty with good shocks before.
Old 01-22-2012, 05:16 AM
Adobe 11SD's Avatar
Adobe 11SD Adobe 11SD is offline
Adobe 11SD is gaining momentum as a positive member of FTE.
I went through 2 sets in 22K miles, replaced them with the Bilstein 5100 also.
Old 01-22-2012, 01:46 PM
slipry14 slipry14 is offline
slipry14 is starting off with a positive reputation.
I replaced mine at around 1000 miles. 2 didn't rebound at all.
Old 01-23-2012, 11:31 AM
darren32's Avatar
darren32 darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
Quote:
Rancho suspension in a thread on this site said "They are a $40.00 shock built to Fords specifications". They are junk. IMHO it is a sell out for Rancho to put their name on such junk. Because of this I will not consider Rancho in the future.
Test driving the new Rancho RS7000MT shocks for the 6.0L bismic 6.0L Power Stroke Diesel 49 11-03-2015 06:03 PM
Rancho 9000 adjustable shocks....WOW!! jonrjen 6.7L Power Stroke Diesel 16 10-12-2015 02:28 PM
Rancho 9000 Shocks question for those who tow jonrjen 6.7L Power Stroke Diesel 10 08-07-2015 10:34 AM
Shocking Question jonrjen 6.7L Power Stroke Diesel 34 03-07-2015 03:18 PM
Shocks CurtSD 1999 to 2016 Super Duty 32 04-22-2014 06:20 PM
Tags
2002, 2006, 2011, f150, ford, fx4, issue, kind, pkg, rancho, rs9000, shock, shocks, shokcs, towed, trailer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
