FX4 Rancho Shocks, Who has checked -were they good or bad - Page 2 - Ford Truck Enthusiasts Forums
Old 01-23-2012, 01:05 PM
TrickTruck TrickTruck is offline
TrickTruck is starting off with a positive reputation.
I have RS9000 on my Toyota. After 10+ years Rancho replaced them for free because the adjusters seized up - they functioned fine otherwise. The new ones are still working great.
Very surprised to hear that whatever they are supplying Ford are so bad.
Old 01-23-2012, 01:46 PM
farmerdave farmerdave is offline
farmerdave is gaining momentum as a positive member of FTE.farmerdave is gaining momentum as a positive member of FTE.
Changed them out at 34k miles. Yep, all 4 would not rebound but I don't think that is an accurate way to measure if a shock is working properly.
Old 01-23-2012, 03:40 PM
darren32's Avatar
darren32 darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
Quote:
A gas changed shock will rebound on it's own......unless it has lost it's charge.
Old 01-23-2012, 07:22 PM
If it lost its nitrogen charge wouldn't the shock still function(in a diminished capacity) if it still had the hyd fluid inside? That's what I'm getting at. The nitrogen pressure is used primarily to reduce foaming in the Hyd fluid?
Old 01-23-2012, 07:49 PM
Fontana Fontana is offline
Fontana is gaining momentum as a positive member of FTE.Fontana is gaining momentum as a positive member of FTE.
I changed mine to Bilstein 5100 at 6K. My two front Rancho shocks were completely shot. The two rear seemed to have some life left in them. New truck/unused bed/heavy front end
I agree with what you are getting at here. Those shocks were atrocious and probably the biggest insult to consumers. I'm just glad I had the sense to replace them as soon as I did.
Old 01-23-2012, 08:21 PM
jmcquarry's Avatar
jmcquarry jmcquarry is offline
jmcquarry is starting off with a positive reputation.
My 2010 KR 250 had the FX4 pkg and I traded it in with 13k miles,,,noticed the difference in ride immediately with the 2011. Then I saw the thread ref the issue with the stock Rancho Shocks several months ago. At that time I moved up to the Bilsteins,,,with just a few thousand miles on my new truck the Ranchos were at less than full capacity,,,
Old 01-23-2012, 08:24 PM
Dim Sum's Avatar
Dim Sum Dim Sum is online now
Dim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant future
I might mail my old shocks to the Ford CEO .... just to let someone know of the junk they are putting on these $50+k trucks.
Old 01-23-2012, 09:13 PM
montanacw montanacw is offline
montanacw is starting off with a positive reputation.
I just replaced my factory junk Rancho shocks at 59,000 miles on my 2011 F350 they were trashed.....I put on the rancho 9000 with the my ride controller, I am impressed!
All of my other Super Duty's I have used Bilstein shocks, good shock but wanted to try this my ride set up.....So much nicer ride and no more shimmy on the highway.....
The original rancho shocks say Motorcraft on them......not sure if Rancho even made them
Old 06-14-2012, 07:54 AM
DSL_PWR's Avatar
DSL_PWR DSL_PWR is offline
DSL_PWR is starting off with a positive reputation.
Just found this thread so sorry for the late post. Might want to look at Fox Shocks as well. Just picked up a 2012 F350 and with 250 miles those shocks go on today.
Old 06-14-2012, 03:32 PM
mrjc's Avatar
mrjc mrjc is offline
mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.
Got Bilstiens for the back at 1k miles. Rancho branded units didnt rebound (at 1K miles) Dont know if that really is a good test either, but I like the ride, no bounce, no bumping, going to put them on the front as now at 5K miles.
Old 06-14-2012, 07:15 PM
RM2012F350's Avatar
RM2012F350 RM2012F350 is offline
RM2012F350 is starting off with a positive reputation.
You think they don't know????
Quote:
Really? They know....
Old 06-14-2012, 07:47 PM
PITS's Avatar
PITS PITS is offline
PITS is gaining momentum as a positive member of FTE.PITS is gaining momentum as a positive member of FTE.
I took my truck in for the NOX recall this week and while there I asked them to check the shocks because the ride has gotten progressivly bouncy. I have a fresh set of Rancho 9000XLs ready to put on but I am going to force them to relpace the FX4 OEM crap first under warranty and then immediately change them out myself. Yes, I know they are $5 shocks but at least the bolts won't be as rusted on...
I go to pick up the truck. "We looked at the shocks and they all still look fine". Next time they are going for a ride with me. I am a patient guy so I drove home this time...boing boing boing. Still not totally undriveable but getting worse every day.
  #28
Old 06-14-2012, 08:24 PM
cabindoc's Avatar
cabindoc cabindoc is online now
cabindoc has a very good reputation on FTE.cabindoc has a very good reputation on FTE.cabindoc has a very good reputation on FTE.
I changed out the front (to 5100's) at about 9000 miles but for whatever reason never got to the rears. Lately, (34,000 mi) it was like a pogo stick, so last week I put on a set of 5100's on and man, what a difference. Shouldn't shocks last 60,000 miles?
  #29
Old 06-14-2012, 08:37 PM
lbersude lbersude is offline
lbersude is starting off with a positive reputation.
Rancho Shocks
In talking to my dealer he said the shocks must be leaking to be under warranty. Mine were not but they where shot at 25K. Got new Bilstiens and now the truck is better than when it was new!
2011 F-250 4x4,Off Road, Crew Cab, Lariat 6.7 L Oxford White, Adobe Tan special edition Seats, 2011 32rlts Jayco Eagle
  #30
Old 06-14-2012, 09:20 PM
dmags dmags is offline
dmags is gaining momentum as a positive member of FTE.
Has anyone without the FX4 checked there shocks ?
After reading this it makes me wonder
How much will 4 new shock $et me back?
Test driving the new Rancho RS7000MT shocks for the 6.0L bismic 6.0L Power Stroke Diesel 49 11-03-2015 07:03 PM
Rancho 9000 adjustable shocks....WOW!! jonrjen 6.7L Power Stroke Diesel 16 10-12-2015 03:28 PM
Rancho 9000 Shocks question for those who tow jonrjen 6.7L Power Stroke Diesel 10 08-07-2015 11:34 AM
Shocking Question jonrjen 6.7L Power Stroke Diesel 34 03-07-2015 04:18 PM
Shocks CurtSD 1999 to 2016 Super Duty 32 04-22-2014 07:20 PM
Tags
2002, 2006, 2011, f150, ford, fx4, issue, kind, pkg, rancho, rs9000, shock, shocks, shokcs, towed, trailer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
