1951 F1 Flathead V8 Aluminum Radiator - Ford Truck Enthusiasts Forums
Old 01-21-2012, 05:33 PM
1951flatheaddave 1951flatheaddave is offline
1951flatheaddave is starting off with a positive reputation.
Anyone have any opioions or suggestions where I can find a good quality aluminum radiator for my flathead?
I found this one and wasnt sure if anyone bought one from him or had a better suggestions.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Thanks in advance, Dave
Old 01-21-2012, 06:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
No experience, but it looks and sounds like a quality product. It should be at that price.
Old 01-21-2012, 07:10 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
I bought a radiator on ebay that was cheaper than that. $300 including shipping
so did old_dan. here is a link to a thread. post#2 is a pic. I will look on ebay for the link.
http://www.ford-trucks.com/forums/11...n-it-cool.html
Old 01-21-2012, 07:19 PM
1940 to 42 ford FLAT HEAD aluminum radiator direct fit MADE IN USA !!!! | eBay
This will get you to their ebay store, I know this isn't the particular radiator you need, but if you read at the bottom of the page. they make all kinds.
Both old_dan and I bought from them, mine in still not installed but it's a nice radiator. it's not polished and there are unsmoothed welds. I didn't care about that, just wanted a good functioning radiator.
edit: here is their weblink http://www.wwwsuperiorradiator.com/50s_carstrucks
I did a "best offer" on ebay $250 and got mine plus $50 shipping.
I also mentioned our forum in hopes to help out other on here...don't know if that helps but it's worth mentioning!
That's all I got to offer!
Old 01-22-2012, 08:36 AM
Did the rad fit with no modifications? Were the rad hoses the correct size or did you have to scavenger for ones that would work? I only ask because I bought an aluminum one for something else and the rad hoses were different size and I had to scavenger for hoses that would work. Than ks for the reply
Old 01-22-2012, 10:12 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Hi
Sounds top quality and good price depending on what shipping ends up to be.
Old 01-22-2012, 10:45 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
That one looks expensive. I bought mine from LMCTruck.com and it fit and works great for $299.95. Just make sure that you order a radiator cap with it as your old one will not fit on the new radiator neck properly.
Old 01-22-2012, 11:58 AM
The only thing about the one old_dan and I got, is you have to drill your own holes to mount it. It fits the radiator support perfectly. You can specify what size you want the inlets,outlets to be. also you can get it with or without the transmission cooler.
Hopefully Dan will drop in here!
Old 01-22-2012, 04:52 PM
Was the one from LMC aluminum?
Old 01-22-2012, 05:23 PM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
no the lmc one isn't but other then weight why do you want aluminum
Old 01-22-2012, 06:27 PM
I really Didn't consider weight, I have read that aluminum dissipates heat better and it looks better in my opinion. I have always had good luck with aluminum and my vehicles have run cooler with them. I am more into them for the good look though
Old 01-22-2012, 07:41 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
If that flathead isn't cleaned out really good any radiator you put in will get plugged up and it will run hot
Old 01-22-2012, 08:34 PM
copper disapates heat better. 4tl8 is right on the money clean all the old casting sand and all the other gunk outta it first
Old 01-22-2012, 11:20 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Copper conducts heat better but the tubes are made of brass, which conducts less per square inch surface area than aluminum. It's all about the money... An aluminum radiator will have different number of tubes and different sizes of tubes than a brass radiator. If copper (the main ingredient in brass) was cheap, we'd all have brass radiators. But it isn't, so almost all OEM radiators are aluminum.
Brass radiators are easier to repair if they get a pinhole leak, that is the biggest advantage IMO.
Old 08-29-2013, 04:24 PM
DW SD DW SD is offline
DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.
Could anyone here measure the core size of the Superior Radiator bolt in for the 1948 to 1951? I have a brass / copper that appears to work well with a 22" x 22" core. I'm in the middle of an engine swap and want to have it gone through just as insurance. ~ $127 to remove the tanks, rod out the cores and flow test.
Am thinking I might just buy new, but am debating. Anyone have cooling issues with a large V-8? I'll be running a Fuel Injected 6.2L.
Thank you,
Doug
1951 Marmon Herrington 1952henry 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-28-2015 12:23 AM
Chinese aluminum radiators for flathead V8? brit_wheels_fan 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-31-2013 12:25 PM
Aluminum Intake Question 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 09-22-2011 03:25 PM
1951 f1 v8 4 soeed question 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-19-2011 05:38 PM
Pro-Comp Ignition System 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 09-16-2011 06:47 PM
Tags
1947, 1950, 1951, aluminum, f1, f100, f2, flathead, ford, putting, radeater, radiator, size, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
