Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Sign in using an external account
Register Forgot Password?
  #16 (permalink)
Old 01-24-2012, 06:53 PM
732t37's Avatar
732t37 732t37 is offline
Garage is empty, add now
732t37 has a good reputation on FTE.732t37 has a good reputation on FTE.
A granny gear is also good for if you live in a place that has a lot of traffic lights and congestion
__________________
6>8. If you think I got my math mixed up, you might have your Fords mixed up.
Pardonnez mon français, s'il vous plaît
  #17 (permalink)
Old 01-24-2012, 07:02 PM
fordman75 fordman75 is offline
1996 Ford E250
My Garage
fordman75 is gaining momentum as a positive member of FTE.
Quote:
Yes it is! I love grany low in stop and go traffic! It makes the guy next to you(or in front of you ) in the prius crap his pants, when you give it a little too much of the old go pedal and the truck launches forward!!
__________________
Ted
54 Ford F100 4x4 project
  #18 (permalink)
Old 01-24-2012, 08:27 PM
732t37's Avatar
Priused drivers never shut up about how little fuel their car uses (notwithstanding the fact it's about as practical as a moped). Therefore, I like to do them a favor by broadsiding their cars so they stop using fuel altogether.
On the subject of transmissions, though, make sure you pay attention to the R/A ratio too. I feel like a lot of guys get all tied up in engine/trans and forget this critical detail. (Yes, I learned this the hard way too- STAY AWAY FROM CODE 12!!!)
So make sure you (OP) check that door sticker when you go to look at anything. You might be like me 3 years ago and assume every truck has a reasonable ratio, but there are some really wierd ones lurking out there!
__________________
  #19 (permalink)
Old 01-31-2012, 09:17 PM
diesel-kid's Avatar
diesel-kid diesel-kid is offline
diesel-kid is starting off with a positive reputation.
is there a block difference or a head difference through the years with the 300?
  #20 (permalink)
Old 01-31-2012, 10:07 PM
1996 Ford E250
My Garage
Quote:
Not a whole lot. the 65-66 blocks have a smaller thrust bearing.
67-86 pretty much the same blocks.
The only things that changed on the 300 heads from 65-86 was the rocker arm designs and air injection. If I remember correctly there are 3 different heads when it comes to rocker arm design. One without built in push rod guide slots in the head ( rail type rocker arms ) , one with guide slots in the heads ( standard rocker arms ) and then the later heads pedestal type bolt in rocker arms. Then there are heads with air injection ports and those without. All carbed 300 head will have combustion chambers right around 76cc.
The 87+ ( EFI ) blocks don't have the opening for the mechanical fuel pump.
The 87+ EFI head have the pedestal mount rockers arms and a smaller fast burn combustion chambers. And they have more mounting holes for the manifolds.
I might have missed some thing that is a basic description of the changes.
__________________
Ted
  #21 (permalink)
Old 01-31-2012, 10:16 PM
diesel-kid's Avatar
perfect, thank you very much for the info
  #22 (permalink)
Old 02-01-2012, 09:33 AM
Ken(Ark) Ken(Ark) is online now
Ken(Ark) is starting off with a positive reputation.
Quote:
Originally Posted by 351M View Post
I had an '84 F250 Supercab 4x4 here that had left hand thread front and rear. Is it possible someone swapped the studs on the front?
My '84 work truck has 1/2 rh lugs on the front and the 9/16 or 5/8 can't remember which on the rear with one side left hand threads , depending on which side the drum was installed after a brake job .
I think the front rotors have been replaced to the smaller rh lugs .
I had another diesel '84 with all four right hand large lugs but the motor went south so I finally replace the one left hand drum on the work truck , Thank God , it really annoyed me , he he .
  #23 (permalink)
Old 02-03-2012, 12:54 PM
ftrk66's Avatar
ftrk66 ftrk66 is offline
1966 Ford F-100
ftrk66 is starting off with a positive reputation.
Great info, just want to know about the intake manifolds on the 300's, do they have the same studs space throughout the years, because late carb will not fit right on, that's what I had once when I tried to put 84 Carter YFA carb on my 66 Ford 300.
  #24 (permalink)
Old 02-03-2012, 09:04 PM
1996 Ford E250
My Garage
Quote:
I don't have the exact info on the intakes. I don't usually mess with the stock intakes. I usually toss them and just run a 2V or 4V carb.
I do know there were some with different carbs. I've stumbled across some older vans that had some little carb on them. It might have been an Autolite 1100/1101. But I'm not sure, that was over 10 years ago. I'm not sure if the stud spacing was different either.
__________________
Ted
  #25 (permalink)
Old 02-04-2012, 09:05 AM
ftrk66's Avatar
1966 Ford F-100
Thanks Fordman 75, so does the 2 v carb fit in the place of 1 brl carb, is there any power gain?, does it burn more gas than the single brl?.
  #26 (permalink)
Old 02-04-2012, 04:27 PM
1996 Ford E250
My Garage
You can run a 2V on the stock intake with a 1V to 2V carb adapter. But the gains from doing this are fairly low.
If you go with an aftermarket intake like the Offenhauser C-series you can run a 2V carb with a 4V to 2V carb adapter. You'll get a good performance increase.
The gas mileage depends on how you drive. If you have a heavy go pedal foot then yes the mileage will drop.
__________________
Ted
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
