HR-1 brake valve
HR-1 brake valve
I have an 87 F700 with an HR-1 brake valve mounted on the firewall. It seems to have developed a leak. Is it something that can be rebuilt? Do they typically leak at a fitting? It seems to be leaking from between the mounting bolts in the back, not near a fitting. Could it just develope a crack in the housing? Lots of hoses to remove to dissasemble, so I want to know what I am getting into first. Thanks
Ok, I did not know the valve split in half. I do believe its Hydraulic over Hydraulic. I do not think there is air for the parking brake. Is the oring repair a tough job? Do I need to by a kit or just size up the orings at the parts store? I would do all of them while I had it apart.
She's getting old, but very reliable. Thanks for your help..
Marked: E5HT-2A449-CB = Ford part number: D5HZ-2A449-A .. Rear Wheel Brake Relay Valve Assy-Use with Brake Skid Control / Obsolete
Last MSRP: $207.92 // Dealer net cost: $110.20 / Applications: 1975 F700/900 from serial number W40,001 & 1976/94 F700/900.
MANDERBACH FORD in Temple PA has 1 = 610-929-3683.
WELFORD HARRIS in Siler City NC has 1 = 877-346-2396.
WOODY FOLSOM FORD in Baxley GA has 1 = 912-367-2466.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
KINSEL L/M in Beaumont TX has 4 = 800-816-2894.
Call around for the best price.
Obsolete parts prices can vary wildly from one source to another.
Bill, I ordered the part and it came in different. I sent it back. I just noticed the original E5H1 number I gave you, and the one you referenced (E5HT) for the cross to Ford's number was different. Is it possible you could look it up again? I really appreciate your helping me with this. Old trucks are becoming harder to find parts for!!
Would a photo help??
emgee
05-11-2015 08:36 PM
shameless
10-17-2011 06:57 AM
Mr. Farknocker
1983 - 2012 Ranger & B-Series
02-07-2005 06:22 AM
