will a bad CPS throw a code - Ford Truck Enthusiasts Forums
Old 01-21-2012, 08:43 AM
blrman1962 blrman1962 is offline
blrman1962 is starting off with a positive reputation.
llooking fo help will a bad CPS throw a code truck just dies on the road kind of sputtered and died whe motor will crank and the tach does not even move I put my auto engineuity on it no codes I cant figure it out. I thiought it was gelled up but i cant find that either truck has been plugged in all night and still nothing. just cranks does the CPS fit the senerio. please help
Old 01-21-2012, 08:57 AM
Justin03PSD's Avatar
Justin03PSD Justin03PSD is offline
Justin03PSD is gaining momentum as a positive member of FTE.
Sometimes yes, sometimes no. I've experienced both. If you have a spare it's easy enough to swap out.
If you suspect a fuel problem open the drain on the bowl and see what you get.
Also could be oil / hpop related.
Old 01-21-2012, 09:13 AM
I opened the fuel bowl and there is liquid fuel in the bowl and did a buzz test the injectors sound good I am hoping that it is the CPS
Old 01-21-2012, 10:44 AM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
With AE on and watching engine RPM, does it show cranking when you try to start it?
Old 01-21-2012, 12:13 PM
I have not looked at that yet and if it does ddoes that mean a good CPS and I need to look at other things
Old 01-21-2012, 12:22 PM
If AE shows RPM your CPS may very well be good since that is where the PCM gets it's signal from. Like mentioned before, throw a spare one in and see if it helps.
Sounds to me more like an oil problem or possibly IPR related. This could be a short or something else.
Old 01-21-2012, 12:35 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
This sounds like fuel bowl heater, don't remember what fuse it is on a 99 but on a 2000 it is fuse #30.
Old 01-21-2012, 01:14 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
If you are not getting a WTS light do as Richard said and check fuse #30 under dash.
Old 01-22-2012, 03:32 PM
UPDATE not the fuel bowl I got that one in northern maine last year at 40 below LOL that was a cold walk back it appears that it was the CPS i changed and it took a while be got her to start drove the 30 miles to work no problem. we will see when I go out there to start her up. I was wondering if anyone knows what the hpop discharge pressure should be at idle thanks for all the help
Old 01-24-2012, 02:00 PM
mark3885 mark3885 is offline
mark3885 is starting off with a positive reputation.
Min 500psi, my 2000 ,usually about 580 at a warmed idle
Blue CPS Problems?? duggyb 1994.5 - 1997 7.3L Power Stroke Diesel 15 03-08-2016 07:45 AM
Truck died on me, need a little help Az_Green_Machine 1994.5 - 1997 7.3L Power Stroke Diesel 20 07-11-2015 11:52 AM
CPS help please.....Pulling my hair out!! 97bamastroked 1994.5 - 1997 7.3L Power Stroke Diesel 12 09-30-2012 03:16 PM
Another "Truck died, no start" thread... Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 27 04-23-2011 11:22 AM
Code P0344 CPS and P1280 ICP now what? jnye6625 1994.5 - 1997 7.3L Power Stroke Diesel 20 03-07-2007 02:51 PM
Tags
04, 2000, 73, 73l, bad, code, codes, cps, ford, fuse, intercooler, lightning, moves, tach, throw, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
