CUSTOM CCV MOD FOR 6.4
2 -16 steel male JIC x -16 male oring fittings
2 -16 XRP female 180 degree fittings
2 -16 XRP female straights
2 -16 steel male x female weld on
16' -16 XRP ano hose (could be less or more depending where u put it) mines on the outside frame rail about center of pass door.
1- Racor CCV4500
1- JB weld kwik pak
I cut the flared ends of the oil fill canister on the truck along with the flared end on the where it connects to the intake pipe between the filter and the turbo. I than took the weld on fitting and with my lathe machined the fitting to fit snug on the oil fill canister and intake pipe fitting. I think u could also simply sand the pipes a little for a snug fit in lue of using a late. After which i epoxyed the -16 weld on ends to the original connection points on the intake and the oil fill canister. Mounted the filter and made the final connections.
So after i week i tried draining the filter but there was nothing to drain so i took the can off and found just a little residue in the can but the filter seems to be doing a good job. I was concerned that id have to drain it allot but, looks like it will go for awhile before it needs to be drained. All and all I'm pretty happy so far seems to be working well.
Thank you. I reviewed the pictures closer and see the designation, but I am still confused as to the overall effects of the modification. Is the modification worth the time and money invested? Is it to protect the engine from possbile damage or just probable damage? Just trying to understand the desire to install the system?
Dave
Dave
The overall effect will prevent any oil from the crank case from getting into the intake system where it shouldn't be. In the beginning, you may not have allot of oil getting by but as your engine begins to wear, it can start to develop into an issue. The results are an intake all clogged up and gummed up do to excessive oil getting into it. This will result into a vehicle sputtering and running rough and eventually breakdowns.
Thank you. I understand. I am sure I will have many questions when I see modifications and do not understand the why. My truck is a 2010 with 22,900 miles on it. Bought it used ( December 14th) as a certified ford vehicle with 21, 500 miles on it. As you can see only have about 1,000 miles since I first bought it, so it is very new to me. Thanks again for putting up with my ignorance. (another thought) How do you like the Banks Cold Air Induction and the Ravelco Anti Theft Device?
Dave
Dave
Dave
Dave
this is the effects over time (100,000+ miles sometimes less)of the CCV system and the EGR system on your intake. I believe this has more to do with Egr but the ccv does contribute to the issue. The article is for a 6.0 but the 6.4 is similar in function. The investment is up to the user some people never have had this issue other have, i did it because i removed both egr coolers and this was the last thing to could contaminate the intake.
I've been very happy with the CAI, the install is really easy and the fit and function is very clean. I like how the design as it promotes a nice smooth flow of air into the vehicle.
The ravelco is great piece of mind. Think of it as the ultimate kill switch. Only thing you have to worry about is the vandals that break into the vehicle and the thieves that use a tow truck. The first can be deterred with an alarm the second, well as they say, if they really want it their gonna get it. But it will stop the hot wiring thieves as it won't be easy to bypass.
I want to thank you for the responses to my questions. I have been reviewing earlier posts to gain an understanding of our diesel engine. If I see a post that I want to keep and review I print the post and place it in a binder which I plan on building for reference. I had noticed the information on various modifications (cold air inductions, diesel programmers, anti-theft devices, and others) and I have gone to various websites to review information. Luckly for me, I live in an area where truck theft is very low, however, I will be giving the Ravelco lock system some serious thought, I just have to get to a state where their is a dealership that installs. Currently the closest is over 6 hours away. Also after my warrenty expires, I will be adding a few modifications to my vehicle. I normally keep my trucks for sometime, I had a small Toyota pickup for 17 years and would still have it if it had not been involved in an accident, and I still own a 1999 F150 which a co-worker wants to buy. So I plan on keeping this F250 for sometime, and I will keep the maintenance up-to-date. I have been researching for the tech bulletins which come out and I was wondering if there is a website that lists all of them for the past 2years so that I can review them at once.
Dave
Dave
