CUSTOM CCV MOD FOR 6.4 - Page 4 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #46
Old 07-31-2013, 10:24 PM
Allstar recovory Allstar recovory is offline
Allstar recovory is starting off with a positive reputation.
is it possible to just vent the ccv into the atmosphere? thats what i did with my lightning. some guys used oil catch cans others just let it vent, i just used a mr gasket breather and a 90' elbo. can we do that with the diesels or is there to much oil coming through?
  #47
Old 07-31-2013, 10:27 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
You can vent to atmosphere. I've been doing it for a while. I used a 1" ID heater hose down by the frame rail under the bed. There is a decent amount of vapor occasionally and I am often told that my truck is smoking.
Just changed out my cold side CAC pipe and not a trace of oil residue. Was very pleased.
  #48
Old 08-23-2013, 04:06 PM
FivePointo's Avatar
FivePointo FivePointo is offline
FivePointo is starting off with a positive reputation.
I've always wondered why no one has done this, I did it to my race car, most drag racers do. But run the CCV to the vehicles exhaust. I know in drag racing applications it's done for different reasons. Why not run a hose from the CCV into the exhaust with a 1 way valve? Lets assume you have a cat and dpf delete. I get why you wouldn't if they are still in place.
  #49
Old 08-26-2013, 01:12 AM
TIRE FRYER's Avatar
TIRE FRYER TIRE FRYER is offline
TIRE FRYER is starting off with a positive reputation.
Yeah, why hasn't anyone done that yet? It may improve ring seal as well like in drag race applications. You can always put it after the cat/dpf if you still have that.
  #50
Old 07-12-2014, 01:16 AM
2005_HARLEY_F250's Avatar
2005_HARLEY_F250 2005_HARLEY_F250 is offline
2005_HARLEY_F250 is starting off with a positive reputation.
Looks great!
  #51
Old 05-26-2015, 11:40 PM
08f250pwrstroke 08f250pwrstroke is offline
08f250pwrstroke is starting off with a positive reputation.
Mishimoto baffled catch can and 7' of 1" XRP heater hose.
Mishimoto mounted up front. Keeping the 1" hose as close as I can to the catch can
  #52
Old 05-27-2015, 01:12 PM
CKetchum's Avatar
CKetchum CKetchum is offline
CKetchum is starting off with a positive reputation.
That Mishimoto Catch Can install looks good and easy to access! I saw they have lots of hose and fitting options. I probably should do this mod...
  #53
Old 07-02-2016, 06:31 PM
buckiii2 buckiii2 is offline
buckiii2 is starting off with a positive reputation.
ccv reroute
Quote:
Why are you running a hose back into the intake?
  #54
Old 07-06-2016, 09:41 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
where would you put it? After the filter it is clean air that can routed back into the intake.
  #55
Old 07-06-2016, 10:09 AM
Quote:
Clean? Most people route it down the frame beyond the cab. Some people just vent it into the air some place an oil catch can with an filter on top.
  #56
Old 07-06-2016, 10:24 AM
senix's Avatar
The ccv mod in this tread routes the hose from the oil separator to a racor filter. Then the clean air back into the intake.
This is not a oil canister to frame and then to the open air.
the idea is too catch the oil so you don't just dump it all over.
  #57
Old 10-14-2016, 01:45 AM
Quote:
I'm going to change out this catch can from out in front, to the rear of the truck with a breather on it. When I would disconnect the hose going back to the intake, there would oil in that hose. Too much blow-by and combined with the turbos sucking that vapor back in.
  #58
Old 10-16-2016, 04:10 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
its routed back to the intake to send fuel vapors into the intake. as engines wear, more blow by, recliaming the fuel vapors helps mpg.
those catch cans probally catch a lot of the fuel vapors as well as the oil, so your not going to get a lot of fuel vapoers back into the intake...but you will get sum.
the other value sending the air back to the intake has is that the air going back to the intake will be colder and denser than the air going directly from the vent to the intake. the air gets colder due to the catch can being in front of the radiator and most of the hoses being in front of the radiator.
Also, I got sopped by environmental protection NYC police for smoking more than 3 seconds while my truck was doing its regen thing.....dont want to add to that dripping oil from "the hose to chasis to the ground" approach.
  #59
Old 10-19-2016, 09:52 AM
Tractionless Tractionless is offline
Tractionless is starting off with a positive reputation.
IT would sure be nice to find a baffled catch can with 1" inlet/outlet.
CCV re-route. Smell? forced5 6.4L Power Stroke Diesel 0 07-03-2016 12:04 AM
CCV mod 7.3-Stroker 1999 - 2003 7.3L Power Stroke Diesel 16 12-20-2014 11:35 PM
After repair issues dman255 6.4L Power Stroke Diesel 9 10-05-2014 01:11 PM
CCV mod question on vented gasses.... afonda 1999 - 2003 7.3L Power Stroke Diesel 8 04-22-2009 04:15 PM
CCV mod pics tndiesel 1994.5 - 1997 7.3L Power Stroke Diesel 20 03-11-2009 04:24 PM
Tags
64, bypass, case, ccv, crank, delete, diesel, egr, elite, ford, mod, modification, razor, system, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
