Front Brakes Locked Up - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-20-2012, 09:46 AM
kass kass is offline
kass is starting off with a positive reputation.
9 degrees this morning in Columbus, OH. Backed out of the driveway this morning and went to go forward and front wheels won't turn. Truck will back up in reverse, but will not only go forward 5 feet and then the brakes lock up in the front.
Have had issues with front brakes for years (03 Ranger XLT, 4WD) locking up when raining outside, but always went forward a few feet and brakes unlocked. Not happening this morning. Any ideas?
Old 01-20-2012, 11:30 AM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
Possibly bad brake hoses. Or maybe moisture in the brake fluid at 9 degrees if it had any water content if will freeze. Do you have any pulsateing when the brakes are applied like the rotors are warped? Does the brake pedal have any free travel? Like maybe a stuck piston in the master cylinder? Maybe this will be a start?
Old 01-20-2012, 11:55 AM
Thanks for responding. Definitely no pulsating when the applying the brakes ever before this morning and during this morning. Rotors are fairly new so I think warping is ruled out. Also, no free play in brake pedal.
Moisture in the brake fluid came to mind or a stuck piston in the master cylinder. Would water in the brake line /stuck piston in master cylinder allow me to back up, but not move forward?
Old 01-20-2012, 02:22 PM
wp120470's Avatar
Possibly, But you are sure its the front brakes that are locking up? Cause it sure sounds like a problem that usually happens in the rear with the parking brake.
Old 01-20-2012, 02:27 PM
Yes. The back wheels were spinning on the icy road as I tried to rock back and forth and work the rotors free.
Old 01-21-2012, 07:23 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
please create a signature of your truck.....include as many details as possible
Old 01-21-2012, 01:08 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
seems to me it happens more often but because the road isn't dry it is most noticable when wet or slick. It would take a heck of alot of moisture in the system to cause a freeze up, plus it happens in the rain, I'll say that aint it. Probably not master cylinder cause the rear should stay locked up also. I have had all sorts of problems with stuck calipers, and then there is the hoses. Some hoses that have a metal bracket wrapped around them used to mount to a part of the truck can rust enough to constrict the hose and not allow fluid to flow back. A cheap way to fix this is to just bent the bracket so it isnt so tight around the hose but i would rather just replace them if the lines arent too rusty, calipers are cheap and easy to rebuild if you have the time. Only a couple bucks for a kit at Rockauto.com.
brake locking up???? RSCHAP1 Expedition & Navigator 15 05-02-2016 07:35 AM
2007 F150 jerky stop in forward Paul Larsen 2004 - 2008 F150 2 09-08-2013 11:18 PM
Front Axle Issue 5.0 Heaven 1978 - 1996 Big Bronco 4 02-12-2013 08:21 AM
Something is broken Gus Erickson 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-20-2012 10:38 PM
4x4 grinding and pulls to the left BostonX73 Excursion - King of SUVs 28 03-17-2010 12:36 AM
Tags
1999, brake, brakes, f150, ford, forward, front, lock, locked, move, ranger, rear, truck, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
