Rear Bilstein 5100's upside down - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-19-2012, 08:17 PM
Benny76's Avatar
Benny76 Benny76 is offline
Benny76 is gaining momentum as a positive member of FTE.Benny76 is gaining momentum as a positive member of FTE.
My new Bilstein 5100's are upside down on the rear. Anyone else? It's weird because they only go on one way. The bigger hole at the top and the smaller hole at the bottom. Well, the smaller hole happens to be at the top of the boot and the bigger hole is at the bottom of the shock. However, the stickers are right side up with the shocks mounted inverted like this. So if I swap the bushings around I can get the shock mounted right side up but then the sticker will be upside down. Hmmmm.
Old 01-20-2012, 02:31 AM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
when i installed mine i called bilstein with the same concern. they told me the decal should be right side up.
Old 01-20-2012, 05:15 AM
drey04's Avatar
drey04 drey04 is online now
drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.
I just put some 5100s on my truck. I noticed that too. It appears they can only go on one way because of the bushing size and the label orientation. Mine are mounted boots down.
Old 01-20-2012, 08:43 AM
Benny76's Avatar
Ok. I appreciate the replies. It was late last night and I couldn't call Bilstein. So anyone out there installing 5100's on your 250/350, it's normal to have them inverted. Boots down!
Old 01-27-2012, 05:12 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
I read this thread and was prepared to install my 5100s upside down in the rear, but I just put them in and the boot is on the top. On each shock, the larger diameter bushing hole was on the boot end, and the larger diameter bolt is the top one. I wonder why mine is different than all of yours?
Old 01-27-2012, 07:51 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Quote:
Reduces un-sprung weight.
Old 01-27-2012, 10:43 PM
GCLL GCLL is offline
GCLL is gaining momentum as a positive member of FTE.
I have them boots down on my 2011. They can go either way. They have part numbers for both directions, but I wouldn't let it bother you.
Old 01-28-2012, 12:56 AM
Benny76's Avatar
Quote:
Really? Or you just joshin me here? HAHA cause a shock weighs about 10 pounds. Hard to tell sometimes if people are joking or if there is some real science going on through text.
Old 01-28-2012, 01:03 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Quote:
Interesting??? I never knew the 5100's had two different part numbers.
Now...on my SD...I installed Bilsteins...with the boot down, but mine are the Yellow with blue boot. Not the 5100 silver.
biz
Old 01-28-2012, 01:09 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
This seems to pop up every few weeks.
Bilsteins are normally mounted upside down.
Old 01-28-2012, 01:20 AM
Benny76's Avatar
Just on the rear of a superduty right? Because my front are boots up, my brothers titans are boots up, and all of my inlaws toyotas are boots up. My are the silver 5100's. Not sure about the single positive charged 5100 steering stabalizer. It pulls slighty to the left now because of it. Works good on bumps though.
Old 01-28-2012, 01:47 AM
biz4two's Avatar
Arrow
Benny76 --- Not sure if this issue is model year specific or not...but check this link. It has a video of the 5100's being installed by a FTE member. His rear shocks at the 6:46min are not installed boot down. Just a FYI...
http://www.ford-trucks.com/forums/11...ith-video.html
biz
Old 01-28-2012, 02:01 AM
A/Ox4's Avatar
9 ECHO 1
biz
I watched his video. His rears are upside down. He went boot up out of habit. You can see the logo upside down on the shocks.
Old 01-28-2012, 03:15 AM
MaxxSD04 MaxxSD04 is offline
MaxxSD04 is starting off with a positive reputation.
Bilsteins are designed to be mounted with the label legible no matter witch model you have. hope this helps
Old 01-28-2012, 09:25 AM
I used part # 24-186018 for the front and part # 24-062466 for the rear. If you want a direct replacement for stock then use part # 24-186025. I prefer the boot mounted down.
bilstein shocks donovan 6.7L Power Stroke Diesel 8 07-26-2016 06:08 PM
Bilstein 5100 Oilfield Trash Excursion - King of SUVs 9 03-29-2016 11:29 AM
Bilstein Shocks Installation on my F-250 Adirondacker 1999 - 2003 7.3L Power Stroke Diesel 80 04-04-2015 07:37 AM
2 Lift thread with pictures, math and theory smoky_diesel 6.7L Power Stroke Diesel 34 05-27-2014 11:47 PM
Rough Country dual shock bracket and Bilstein 5100 installed saz2686 Excursion - King of SUVs 0 09-29-2012 01:45 PM
Tags
5100, bilstein, boot, duty, ecoboost, excursion, f150, install, installed, rear, review, seat, shocks, spring, super, upside
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
