Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape head bolt torque specs? 3.0L V6 DOHC
Old 01-19-2012, 08:03 PM
daveya48187's Avatar
daveya48187
daveya48187 is offline
vin code #1. Where can I locate the cylinder head bolt torque specifications? In the Chilton's manual it states six steps, was wondering if this is accurate?
1. 30 ft-lbs
2. tighten an additional 90 degrees
3. loosen one full turn 360 degrees
4. 30 ft-lbs
5. tighten an additional 90 degrees
6. tighten an additional 90 degrees
does this sound right?
Old 01-20-2012, 05:33 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
What year? That is the procedure for an 03, for example.
Keep in mind that the bolts are TTY and are not reusable. They must be replaced when the head is re-installed.
Old 01-20-2012, 08:31 AM
daveya48187
thanks for the reply, it's for an 02 Escape v6.
Old 01-20-2012, 01:37 PM
wptski's Avatar
wptski
wptski is offline
Right from the '02 Ford Workshop Manual:
Stage 1: Tighten to 40 Nm (30 lb-ft).
Stage 2: Tighten bolts 90 degrees.
Stage 3: Loosen one full turn.
Stage 4: Tighten to 40 Nm (30 lb-ft).
Stage 5: Tighten 90 degrees.
Stage 6: Tighten 90 degrees.
Old 01-21-2012, 04:49 PM
daveya48187
thank you
I had a front end collision cracking the cylinder head and am losing anti freeze out the tail pipe. I can't afford to have a garage do the job. will buy a used head from a junk yard. just hope it isn't warped and the surfaces mate up good. thanks again. I feel more confident now.
Binder Guy
3.8 & 4.2L V6
06-16-2017 03:58 PM
TheRon
Bronco II
09-10-2008 05:31 PM
robbi
1997 - 2003 F150
11-24-2007 09:37 PM
4x4powerstroke
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-20-2007 08:56 PM
Boss_358
01-23-2004 11:17 PM
Quick Reply: Escape head bolt torque specs? 3.0L V6 DOHC
