Escape head bolt torque specs? 3.0L V6 DOHC
vin code #1. Where can I locate the cylinder head bolt torque specifications? In the Chilton's manual it states six steps, was wondering if this is accurate?
1. 30 ft-lbs
2. tighten an additional 90 degrees
3. loosen one full turn 360 degrees
4. 30 ft-lbs
5. tighten an additional 90 degrees
6. tighten an additional 90 degrees
does this sound right?
1. 30 ft-lbs
4. 30 ft-lbs
thank you
I had a front end collision cracking the cylinder head and am losing anti freeze out the tail pipe. I can't afford to have a garage do the job. will buy a used head from a junk yard. just hope it isn't warped and the surfaces mate up good. thanks again. I feel more confident now.
4x4powerstroke
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-20-2007 08:56 PM
