351w Head gasket replacement... Sealant or no?
The chilton manual says to use head gasket sealant. From what I've read online it seems like most do not.
I have basic fel-pro gaskets if that matters. The gasket sealants I have are permatex high temp gasket sealant and permatex copper spray-a-gasket.
Advice much appreciated. Trying to get heads on tonight.
What do you mean? do you mean the thread lubricant the bolts come with? yes, that would be a good idea. Just make sure the bolt holes are extremely clean and have no fluid in the bottom of the pockets. Doesn't take a whole lot of grease. Make sure to put some on the bottom of the bolt heads too.
Thanks, Matthew.
Here is what happens when one uses RTV on head gaskets (which only a clueless dumbphuque does):
Do you see the little bits of RTV poking out? Poking out of what, you may ask... from the holes through which anti freeze is supposed to flow(!).
I trust you can see a problem with anti freeze/coolant not flowing through the heads.
Any kind of gel- or goo-type of sealant is going to get squished into those passages when the heads are torqued down; the ONLY "gasket sealer" I have heard of that *might* be OK to use with head gaskets is that copper spray-on stuff but, even then, I wouldn't us it unless I had a specific reason to.
If you are using Fel Pro gaskets, I would follow their instructions....
ben73058
59
07-24-2020 07:17 PM
