Needing a full set, or what are you after? The more info you give, the easier for someone to help you out, or point you in a good direction.
I have two complete engines that need stripped down, but it's not going to happen in the next couple days.......if someone needs the parts though, I could put a bigger priority on it.
yes I was looking for a whole set, as everything else will be new(crank pistons cam shaft lifters push rods I.P. injectors) sorry for the lack of information. MudGuts
I have a full set id sell already pulled They are steel rods so unless you get a set that is bent or broke its ok. Just put new bearing and new bushings in you would be fine. Pm me if you want a set or 2!!!
I'm not sure how forums work about putting your number or email address on here. But I would be interested in a set of connection rods if you have any available.
