Who switched from a diesel?
#46
That is good to hear Byram. My only problem now is figuring how to hook up my 5th wheel. I ordered it with the gooseneck kit, but refused to pay the $1600 for a plain old 5th wheel hitch. I had thought I would use a 5th wheel to gooseneck adapter, but it doesn't sound like a good idea from what I have read. Maybe I can buy the foot adapter for the Reese signature hitch and mount my bed rails to that so my Pro series hitch will mount to the Ford set up.
#47
It seems where ever I search I come across all these people saying the adapter will crack or rip the pin box off the camper. My dad and another friend have used this set up so I thought it was a slam dunk until I typed it into google and came across all the negative information on the adapters. I'm getting off the diesel to gas subject so I'll start a thread in Towing.
#48
Matt Can you give me an idea of RPMs at 70 mph without a load and on level ground? (high gear)
I ordered a 2012 6.2 and can't decide on gears? I will tow about 8,000 lbs once or twice a year, most driving is stop and go not exceeding 55 mph or highway as a daily driver.
Thanks!
Kevin@appelauto.com
Thanks!
Kevin@appelauto.com
#50
#51
If buying a new 5er better check with the builder as they are the ones that well void your warranty if you run the converters. There are some that well void you warranty if you use a 5th Airborne Sidewinder hitch. I ordered my 5er from Arctic Fox and they installed the Sidewinder from the factory but will not install a gooseneck converter and well void my warranty if I installed one. I bought a Reese 18K Signature for my truck. It was a lot cheaper than the Reese 25K Signature from Ford.
I pull a Arctic Fox 5er that is right at 12,000#.
#53
Back on topic,......Forget about replacing your diesel pickup with another diesel unless you have exceptional heavy hauling needs as it is now time to look into the Ford F350 6.2L gas and save $8,000 + over the diesel. I have a 2008, F250, XLT, srw, with the 6.4 diesel and it has been a painful $$$$$ experience to the point that I am pursuing Ford with a Lemon Law suit.The EPA has screwed up the diesel pickup fleet sense 2008 with their DPF/DEF particulate soot filter requirements that the reliability and fuel millage of diesel pickups has suffered a major setback. The price of diesel over regular gas is now $0.50+ along with the huge cost of maintaining a diesel is just not worth the money spent. The 6.2L gas is now being installed in the Ford pickup fleet as a standard option in the F250/350 and is for the most part all the power that you need to haul your slide in camper and is the way that I will go when I win my Lemon Law suit with Ford.
#54
I have so many reasons why I know I should go with a gasser next time around but I do currently pull at 14.5k fifth wheel out here in the west. The *out west* part is about the only thing that is still giving me that bit of hesitation with the 6.2 concept.
If I could know that I'd be able to pull hills closely to the diesel then it'd be an absolute no-brainer for me. I can see myself smiling all the way to bank each and ever time I drove with the gasser, so long as I didn't end up feeling like I had inadequate power for what I do.
#55
I'm hoping this Gasser doesn't come up too short. I know there was a huge difference when I went from my 2003 7.3 to my 2006 6.0. I'm sure this gas motor won't pull like the 6.0, but maybe more like the old 7.3. That thing was slow getting up to speed under a load, but it handled a 20K trailer just fine. Another month or so and I will find out.
#56
I hear you with the *out west*... If you go with a 6.2L...just opt for the 4.30 gears.
I'm in a similiar situation...but going from my 425 ft/lb V10...the less 6.2L. I have to give it to FORD...when numbers are less...they make up for it with the LOW first gear on the 6spd Auto. Plus...offering the 4.30 gears...should help.
biz
#57
biz
biz
#58
I've heard that as well...but nobody has ever confirmed the F150 hp and torque figures.
It is my understanding that the SuperDuty gets a different tune from FORD as well. Which does change the hp / torque figures.
Again...you may be right...and the hp / torque figures we see for the SuperDuty line are virtual with respect to rpm calculations.
I don't think the 6.2L has the same tune. Wish someone would verify it?!?
biz
#59
biz
biz
#60
So,.... why would Ford bolt up to the same transmissions used in the 6.2 & 6.7 engines then install different cams and other internals, use different tuning parameters, have a different part innovatory and put up with all of this added expense because of the (advertised 411 HP) in the F 150,.... is it because of the 6.2 aluminum block 411 HP rating that is installed in the Chevrolet 1500 pickups and that Chevy will not install in their 2500 HD ??? An advertising game of one-up-man-ship and no more,......???????
I wish that the Ford engineers that were on this forum would answer these questions to clarify the perceptions about this new Ford Engine.
