2012 Lariat
2012 Lariat
I have a 2012 F350 Lariat dually without the center SYNC display. On the instrument cluster I can't get the OAT, EGT, etc displayed. Only oil and water temp in the INFO selection. I do get compass direction, and other very basic info. Is there a flash available so I can see OAT, EGT and other engine info displayed.
Jeff
Jeff
The optional message center (within the instrument cluster) only reports EOT and TFT.
The optional NAV unit in the center of the dash would be the secondary screen where SYNC is involved but I don't know if it reports engine information.
Someone here did add the NAV unit (I think it was Shane) but I think it would be very difficult, if not impossible to add the optional instrument cluster message center.
I need to clarify. My Lariat instrument cluster screen shows engine coolant and tranny temps in degrees when you go to the Info selection. Along the top of the screen I see the N,S.W,E direction info in all the driving modes, but not the OAT, which my friend sees with his '11 F350 6.7 Lariat.
I THINK he sees more engine info in the INFO selection, but I'm not sure. I would like to see the OAT information.
on
I have the color LED display standard with the Lariat above the steering wheel, my friend has the same display in the middle of the dash also. His display above the steering wheel has OAT displayed, I can't get it displayed on mine. We both have Lariat trucks, but he has the full SYNC system. So is that the difference, or can I get a flash so I can see the same info.
Ok, I'm getting confused. If you have a Lariat you have the full SYNC system ..... as far as I know there is only one SYNC. Your friend likely has the NAV package which adds a full screen unit in the center dash with navigation and such. And forgive me for being dumb, maybe to early in the am but what is OAT? Oil and Transmission Temps? If so the centre screen can display the oil and tran temps on the gauges screen.
