Part # for coolant crossover gasket on 2002 4.6L SOHC intake manifold
Old 07-24-2012, 08:10 PM
jayton4's Avatar
jayton4
jayton4 is offline
I have a 2002 Explorer, the one with the aluminum block and Romeo heads. I noticed that the gasket on the right side of my picture here was protruding out of the channel it rests in. I then removed the 6 hex head screws holding the aluminum crossover tube to the plastic intake, and found it to be a mess.
I want to replace these two gaskets, but I cannot find any information on them. Google searches say replace with RTV. Is that my only option? If so, which RTV should I use? High temp red?
Old 07-27-2012, 10:43 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Most of the time the channel breaks causing the gasket to push out. The only fix is a new intake.
Old 07-29-2012, 04:09 PM
jayton4's Avatar
jayton4
jayton4 is offline
Dang! You were right. The channel is broken. I was hoping it was just the way it was designed since it never leaked before. Now I'm going to have to use my PI Mustang lower intake that I was planning on using for the PI Headswap on my 96 Mustang GT. Hopefully the lowers are the exact same.
Lordtora1
08-21-2019 11:50 PM
Rockledge
1983 - 2012 Ranger & B-Series
109
10-13-2018 04:37 PM
tbruz
06-03-2016 07:14 PM
MisterRanger
02-02-2013 04:47 PM
90F250351
16
12-05-2006 05:35 PM
Quick Reply: Part # for coolant crossover gasket on 2002 4.6L SOHC intake manifold
