4r100 have to let off to shift - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign In
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 01-18-2012, 07:04 PM
nicke147 nicke147 is offline
nicke147 is starting off with a positive reputation.
Ok guys i have a 2001 f-250 with 125000 miles on it. The issue is that it shift at 3500 rpms or when i let off the throttle i have changed the tps as well as oss or vss..... as well as the torqe converter.... now im at a loss for words does anyone have any help to give!?!? it shifts fine when i walk it on the colomb!!! do u think maybe a cks crank position sensor!!!!!
Old 01-18-2012, 07:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
You would have saved a bunch of money and time if you asked for help before all those "fixes."
You need a trans rebuild. The mechanical diode has failed. It needs to be replaced.
__________________
Mark
Former Ford Automatic Transmission Engineer 1988 - 2007
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Old 01-18-2012, 07:16 PM
can i pull the transmission and replace this diode alone or is this deep in the tranny? may i ask what this does.....
Old 01-18-2012, 07:17 PM
i did the trq converter myself and the converter was slipping to be honest...... plus it was shudderring
Old 01-18-2012, 07:26 PM
hey thanks where would the best place to buy this part
Old 01-18-2012, 08:23 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Heed Mark's words...he helped designed this thing and knows it better than any of us do.
Btw, welcome to the club, I joined February 2006...exact same symptoms. I was crossing a railroad track and stopped at a stop sign. As soon as I started to accelerate, it did the same thing yours did and wouldn't shift until I let off the accelerator. A trip to a dealer confirmed the mechanical diode had failed and my trans needed to be rebuilt or replaced.
Get yourself a BTS trans and you'll never have to worry about this or any other trans issue again.
__________________
Excursion & 6.7 Forum Mod Death Row Inmate #21
The Monster: 2005 Ford Excursion Limited, 4wd "The 6.0" Bulletproofed by Powerstroke Enginuities Straight pipe, Atlas 40, Heavily RiffRaff'd, and Gearheaded
Rudolph: 2001 Ford Excursion Limited, 2wd, "The 7.3" Built with blood and sweat by Me and Riffraff Diesel, heavily modded, also Gearheaded
FTE Guidelines
Old 01-18-2012, 08:30 PM
Tnx guys and thanks mark
Old 01-18-2012, 08:46 PM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
John Wood in Holtville, CA does a nice job if you're located in the west.
John Wood Automotive - Home
__________________
Sean
2000 Excursion XLT V10 4x4 180K, front V's + 2'' level, rear mod'd C's,, 315's, winch bumpers F/R, Viair, Piaa lighting, Hellwig -GermanMike, dual Optimas, sage-brushed patina
Join the So Cal chapter here
Be Like Steve
Old 01-19-2012, 12:07 AM
Does anyone know the ford
part number of the mechanical diode
Old 01-19-2012, 04:20 AM
You don't need the part number of the mechanical diode. You can't buy one, they were discontinued because they were crap. You need to replace it with a sprag type one way clutch. Anywhere that sells transmission parts will have the right parts to do this.
__________________
Mark
Old 01-19-2012, 03:07 PM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
Mark,
What years were the Mechanical Diode used? Phased out?
__________________
Old 01-19-2012, 03:18 PM
Quote:
Originally Posted by grec-o-face View Post
Mark,
Manufacture Date June/July of 2000 to March 2001 any diesel truck with that build date may be affected. Mine was built in October of 2000 and it was affected...
__________________
FTE Guidelines
Old 01-19-2012, 07:20 PM
That's right. It was from the first 2001 built and ran through 3/4 of the 2001 model year.
It was ONLY in the 2001 diesel trucks. Rumors continue that some gas engine trucks got out with a mechanical diode. It's certainly possible. Many, many trucks were built with mechanical diode transmissions before it was discovered that they failed at 4600 RPM. The mechanical diode was left in the diesel trucks because they couldn't reach 4600 RPM. All of the gas engine trucks were supposed to have the transmission replaced with a non-mechanical diode trans before leaving the plant. I could see how a few might slip out.
__________________
Mark
Old 01-22-2012, 04:53 PM
Bryishre Bryishre is offline
Bryishre is starting off with a positive reputation.
Not to keep poking. but mine sometimes wont shift into overdrive unless i let off the throttle. its a 7.3 The build date on the trans is 1e15. meaning it was built in may is it possible to have a mechanical diode. or is it a possible a sensor is going bad? i pull a close to a 10K travel trailer and wouldn't want to get stuck on the side of the road in the summer with family. I mean the kids i can deal with but the wife is a different story. lol
Old 01-22-2012, 08:45 PM
The mechanical diode only affects the 1-2 shift. It has nothing to do with the shift into overdrive. It is not possible for a trans built in May to have a mechanical diode.
At what speed won't it shift to ovedrive? Towing? On a grade? It may be the software preventing the shift.
__________________
Mark
Similar Threads
c6 shifting behavior and vrv adj bolt size jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-08-2014 08:43 AM
02 f150 transmission problems posthumus86 1997 - 2003 F150 22 12-28-2013 02:40 PM
4r100 shifting issues plz help nicke147 Excursion - King of SUVs 3 01-19-2012 11:17 AM
C6 Shifting Problems...what fun TheKirbyMan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 01-10-2012 01:04 AM
PO756 Shift Solenoid B Stuck Off 99ExpHere Clutch, Transmission, Differential, Axle & Transfer Case 2 01-16-2006 04:12 PM
Tags
01, 4r100, date, diesel, f250, manufacture, od, rpms, sensor, shift, shifting, symptoms, throtle, throttle, trans, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
