rear sway bar? - Ford Truck Enthusiasts Forums
rear sway bar?
Old 01-18-2012, 04:29 PM
wicat3's Avatar
wicat3 wicat3 is offline
wicat3 is starting off with a positive reputation.
rear sway bar?
Hey guys might be a stupid question but id rather ask then assume. I have a rear sway bar on my 92 f150 4x4 and it is very noticable and hangs down under the frame. Im not sure if its normal and it dosnt look like anythings missing or what not the sway bar links are attached and look in ok shape but it is noticable when you walk up to the truck and looks so out of place. Is this normal?
Old 01-18-2012, 04:39 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Is this in front of the axle? Some are below the driveshaft or axle housing. Not so good for a 4x4. The Hellwig I had on my '85 E150 went over the driveshaft/pinion. No clearance issues.
If it's all tight, that's probably the OEM (it is OEM, right?) configuration.
Old 01-18-2012, 04:52 PM
wicat3's Avatar
i really dont know. I got it like that from the previous owner. It looks like it connects infront of the rear axle with the sway links
Old 01-18-2012, 05:22 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Does it look like this? If so, its stock. Mine actually lines up with the tires so clearance doesn't seem to be much of an issue unless you hit a giant rock....which is entirely possible if you're having fun..
2012-01-16_11-30-01_628.jpg by Edgethis, on Flickr
Old 01-18-2012, 08:07 PM
wicat3's Avatar
I cant really tell 100 percent edgethis but it does look similar. Do you notice it as you walk toward the truck?
Old 01-18-2012, 08:13 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Looks like somebodies got a leaky pinon seal.
Old 01-18-2012, 08:48 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
The piece with the blue bushings in the pic above I can see that part when I walk towards my truck
Old 01-18-2012, 08:53 PM
You can see the sway bar here
And can just see the bottom of the bracket under the box here
Old 01-18-2012, 08:54 PM
wicat3's Avatar
Midnight1987 so that is.normal then? Because I see the rods and the sway arms look like there at an angle
Old 01-18-2012, 08:56 PM
That is the factory setup
wicat3's Avatar
Ok just.saw your pica,yea that's what mine looks like but I seem to.think its.lower on mine,at least when I look at it.
Old 01-18-2012, 08:58 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Quote:
That was the first thing I noticed in that picture. Haha.
Old 01-18-2012, 09:02 PM
Mine the end are about the same height as the rear diff
Old 01-18-2012, 09:19 PM
Quote:
Odd how something like that first thing a guy notices huh!
I'd have to look but I'm fairly sure mine are exactly the same, recall hitting my **** on em time or two even.
Old 01-18-2012, 09:55 PM
Edgethis's Avatar
Yeah my rear axle needs rebuilt
Rear Sway Bar: 79Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-11-2015 05:14 PM
Sway Bar Differences?? Wilmax Excursion - King of SUVs 32 02-04-2013 10:28 PM
Rear sway bar question TNRTL2 Excursion - King of SUVs 9 12-22-2012 08:10 AM
Plate in front of rear shock?? Pyancey Excursion - King of SUVs 21 10-13-2012 09:55 PM
Anybody got a front sway bar? Sycostang67 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 09-09-2010 09:05 PM
Tags
1989, 1995, 50, 87, bar, f150, ford, rear, stabilizer, sway, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
