Auto Meter Oil Temp Gauge
Old 01-18-2012, 07:55 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
So, a friend of mine gave me an Oil Temperature gauge that his dad used in his truck. His truck had a 460 in it.
I'm unsure if the fitting that's supposed to go into the block is the right size, and I don't know where it installs in the block. I also don't know where to wire it into. It has 1 white wire hanging out the back of it.
I really appreciate any help you guys can give me.
Old 01-18-2012, 08:25 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
I bet the wire is for 12v for illumination.
Old 01-18-2012, 08:33 PM
danr1's Avatar
danr1
danr1 is offline
Old 01-18-2012, 08:36 PM
mpc07005's Avatar
mpc07005
mpc07005 is offline
Is this a gauge or a sender? Sounds like you mean sender. Sender gets wired to gauge. I am unsure of block location.
-Mike
Old 01-18-2012, 08:50 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
That's what I was thinking. Any idea what to wire it into?
Old 01-18-2012, 09:02 PM
danr1's Avatar
danr1
danr1 is offline
Running light circuit.
Guess I should have been more clear, running light was way to general I see now. You'd want the Lt blue-red wire up under the dash, you'd want it wired into the dash lighting circuit as so its light would work with the dimmer function same as everything else.
Old 01-18-2012, 09:04 PM
Midnite1987
IIRC it's the brown wire at the headlight switch you want
Old 01-18-2012, 09:10 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
Excellent. Thank you!
Old 01-18-2012, 09:12 PM
Midnite1987
The guage would have to get a ground somehow for the light to work tho
Shane Carruth
05-29-2016 04:17 PM
Truck Noob
02-21-2016 09:45 PM
frankyford
08-02-2009 03:17 PM
5.8w351
06-23-2006 04:48 PM
97F250LD
12-20-2003 06:32 AM
Quick Reply: Auto Meter Oil Temp Gauge
