Possible 6.7L swap into my truck… Have questions!!
Ok, my buddy just totaled his new 2011 f350 that has the 6.7L diesel. He had gotten side swiped and flipped several times and well all in all it is totaled. He took motor before insurance company came and took truck and gave him money so now we have a 6.7L that is sitting around a garage.
I am getting a 1997 f350 crew cab this weekend. Finally found one i want that has a weak 7.3L in it as is, head gasket blew and injectors are bad, etc etc and either way i got it for a steal of 1500!!!! and i have a free 6.7L as long as i let him drag race once when we are all done.
My biggest issue right now is can i make this motor compatible with the 1997 f350???? I have never heard or seen anyone do this swap. I know it will be very time consuming and costly to an extent but I am going to do a swap whether it be in this or my dad's 2005 f250 that has a 500k mileage 6.0L.
So My biggest issue i see of course is tranny mounting and motor mounting, once that is out of the way, what electrical modifications will i have to make in order to make this work? Electric fuel pumps i know are a must. Will the speedo and tach stay or do i have to swap them out? How will all this work??
Like i said, i have never seen this done and i wouldn't mind being a first to do a rough mock up and perfect it as time goes on, but a little help would be appreciated!!!
on
Don't let me be a Debbie Downer on your project though. If you have the time and wherewithal, can't hurt to hook it up to a cherry picker and see if she fits...
this is a crazy idea, your buddy would be better off selling the motor for parts and you would be better off finding a 12 valve cummins and dropping it in your ford. these new motors are so complicated I am not sure it could even be done. how would you get the new motor to mate with the old trans?? all this stuff is integrated into the engine programming. heck ford didn't even get it right the first outing, most of us have had our truck flashed.
Do you have the complete exhaust system? If you are using a Maxx tuner I suppose you don't need it but the PCM is going to be looking for a ton of sensor signals in the exhaust system. If you have every component that is bolted or connected to the engine with a wire then it might run. But really, every little wire, sensor, and anything else has to be there.
I would bet that the 5R140 would bolt up but you would need a custom tune of the TCM to make it shift.
The instrument cluster probably is important as well in order to display the specific signal from the PCM. The whole thing could be bunk if something like the speed sensor is not there.
Take pics, document your project, and have fun! I dunno if you will get 600HP but you will get a ton of torque and a real nice ride.
The 6.7 and the previous 3 powerstrokes that FOMOCO used as their Diesel engines in the F Series trucks were all 90 degree angled V block. So the block is no larger than the 7.3, actually less displacement, but the cylinder heads on the 6.7 are massive. Aluminum heads with twice the number of components for the valve train. The heads are about 30%-40% wider than 7.3 heads. So the overall width of the 6.7 would be wider at the cylinder heads, but there’s no exhaust manifolds on the outside of the 6.7, they are on the other side of the head, inboard side. You’d also have to use the 6R140 Torqshift trans rather than adapting to use any of the other transmissions FOMOCO used behind they’re diesels. The 3 previous diesels were designed, & manufactured by International/Navistar. There would be absolutely no similarities to as far as bolt patterns, bell housing diameter sizes, or dowel pin locations. Find somebody to write a program that would enable you to operate the powertrain components without it being in derate mode. Ignore the entire DEF system along with the DPF. Depending on what year the 6.7 is makes a pretty significant difference. The latest 6.7’s have more modules that communicate with each other. You’d almost need a stand alone PCM and TCM operating together, but also independent at the same time. I think the 6.7 would be 3-6 inches shorter in height due to the turbocharger location. The 6.7 turbo is above the bell housing and the 7.3, 6.0, & 6.4 turbochargers are in the valley(or just above the valley) of the engines.
Bruce
